Kewl. I need to go over the thread, something I have not done yet.
This open up the question of does it sound similar (worse, same or better). It is unavoidable.
Great work non the less
I am working on a preamplifier project, although on a break from the project until past new years, and will need a power amp (or 2-3) so I might be up for testing it.
What is more important is that I am trying to locate an amp that can qualify as a reference amp for my loudspeaker development side of things. In reality, auditioning a loudspeaker on multiple platforms (classes) is unavoidable.
And once you get into diya, we all know that after a while, one starts to collect em .. lol
A reference amplifier should be transparent and not have its sonic signature.
In that sense, these would not be my choice.
If I should have a single-ended reference, it would probably be the SL, or the XELF :
https://www.diyaudio.com/forums/hea...oneer-super-linear-circuit-3.html#post5296415
The XEN XELF Headphone Buffer
Patrick
Patrick
I will take a look at the links you provided.
My point was not only reference (neutral) but a span of classes as well as clean and noisy. You want both the clean and neutral sound as well as an amp that has a good handling on even order harmonics or the triode effect.
I am considering building myself the Yamaha M-5000, I like the fact that it uses floating ground which should make it very quiet. Then there is the Honeybadger developed here on diya.
Who says you can only have one amplifier
I don't get the chase for very high sensitivity. I usually listen to my music between 70-85dB, so in that regards, the 25ish watts should be more than enough. But yes, according to Herb, this amplifier has no problems rendering the music with a lifelike sensation with 8 ohm nominal loads.The J2 rises high above that dispute between cults. Most likely, the First Watt J2 preserves music's vital chi because it's a simple, high-bias, class-A, single-ended, low-feedback design, created by Nelson Pass—one that has no need to impress the mainstream masses or drive 4 ohm speakers.
- UDNeSS, or You don't need Semisouth's
