UCD 25 watts to 1200 watts using 2 mosfets
Disabled Account
Joined 2005
hi all i have used this schematic with success at +/-85vlts at 2ohms irfb4227 with success i wanted to use high voltage +/-120vlts with irfb4229 with a 4 ohm load is it possible????
I have something faster if you like.
I make this as I am not happy with the output of two legs of resistor under LTP :D
ltspice file is attached in the PDF also.
  • D900 Hybrodin V.1.pdf
Hello gentlemen I made a re-drawing for the AU600 and mister manoj send me the schematic and I notice just a few changes on the older PCB layout what I did is fallow the Rev 3 and go from there, and from the schematic I notice some components that were not present on the older layout PCB but they are in SMD to bottom PCB and what I did is to give them some room to place regular through hole components, this has the Coil Craft coil but I can also modified to get the regular T106-2 also, I will leave images here so I really appreciate if some that has build already can see if there is any bug or errors "do not mind about the coil it can be changed later" :) the other image grey color is for you to see with the silkscreen so no hidden connections , well I will continue here checking the layout still and lastly I found space for some of the LED's but there is one that might be difficult for me to place it is a blue LED SMD that is close to 74HC04 I will try to figure out where I can placed :)
Best Regards
Juanhttp://www.diyaudio.com//www.pinterest.com/pin/create/extension/
  • AUD600 Rev 3.0.1 Juan.pdf
greetings want to ask something maybe its a foolish question do any class d amps
work on a h class step supply and if they work what advantge is there forgive me
for my ignorance just an idea
warm regards
Hi Andrew,
I designed one with same transformer (use doubler ckt)
LV supply +/-45V HV supply +/- 87V. Upper rail switched with IRF9140 and lower rail IRF140
MANOJ
Hi Andrew,
MANOJ
I have a question mister manoj, the power supply circuit this one you see (green) has DC protection or just a soft star circuit time delay seconds for the SPK out ? on lastly I made the updates from the AUD600 circuit you send me and it was difficult for me to find space for the components but I was able to do so, yesterday I forgot to add the 470nF 400V caps and now is on the PCB I think this will be a great project for me :)
Best Regards
Juan
CLASS D
Hi Manoj
greetings testing class d with some rail switchers 220 input AC current
reaching 12 amperes per ch
warm regards
Andrew
