Yes, do please use my values and vary LPF shunt cap by ear, and let us know about your buffer comparisons. Chip Amps will also help keep the planet cool!
'Use a chip amp and save the planet'
Now there you are fdegrove, that's a marketing ploy for you! 😉
Hi Nick,
With this kind of wheather I wouldn't dare to argue.😉
Cheers,😎
Cheers,😎
tbla - that stuff you are drinking doesn't look much like Carlsburg! Are you sure that you are Danish? 😉
oh yes, i'm danish.....but i prefer german weissbeer....
......but this bar doesn't seem to serve anything but stout....ok, lets have another...
Hello guys,
I have a good 70VA 2X30volts toroid transformer left somewhere. Is there any drawback in using it instead of a 2X25Volts transformer to feed the 6922 ? Thanks !
(Sorry I know that this is the kind of question I should asked weeks ago when this thread started)
Elkaid said:I have a good 70VA 2X30volts toroid transformer left somewhere. Is there any drawback in using it instead of a 2X25Volts transformer to feed the 6922 ? Thanks !
+/- 35 DCV is the minimum you want to use so the higher voltage is actually better in that respect.
dave
CE QUI PEUT LE PLUS, PEUT LE MOINS...
If you want to maintain original circuit values, you will have to burn off some volts....
Other than that, no problema.
Just promise this "petit Belge" to send Daniel Lannois over to Belgium at least twice a year, okidoki?
Bon boose,😉
Bon boose,😉
hein ? kessé ça ?
Thanks guys 🙂
Do you know which components/values should be affected by a voltage increase ?
Thanks guys 🙂
Re the Black Beast:
Pretty clever using the cones as pivots/ solid supports.
I considered something similar for my speakers, but decided that I actually wanted the head unit a little decoupled from the bass box. I guess the back bracket has the third point (probably adjustable) I think you have answered a question I had but maybe you can confirm: Is the crack between the bass box and open baffle inconsequential considering the wavelengths involved?
Variac said:Re the Black Beast:
Cones, or 'Tip Toes' are used as you guessed, with the third point at the end of the rear slanted bracket. The crack, or gap, needs to be reasonably small, say 25mm, which is what you see.
There are heaps of interesting tweaks, such as the Vifa XT-25 Tweeter that is recessed to match up with the acoustic offset of the mids. The Tweeter is actually glued into place on sorbothane pads, which acts as a suspension, isolating mechanical energy of the open baffle. The increased sense of focus is quite a nice gain. The crossovers are low order minimum phase 'transient perfect' - 6dB/Oct and 9dB/Oct - also arranged in such a way that at the crossover frequencies you have complimentary phase, this results in very even off axis power response, very little inter-driver phase disturbances, creating a good blending of the drivers. There is one really good thing about this approach, the driver integration is oh so good and the usual driver discontinuities melt away. The critical transition between mids and the XT-25 is just about as perfect as you can get from multi-drivers.
I have several local loudspeaker manufacturers applying the theories and they get good reviews in the local press. The BBs are a labour of love, not profit, so I never charged a cent in passing on my ideas.
The BB IVs are now in their fourth rebuild/incarnation. The original MK I was now a horrible 17 years ago... yikes! I'm growing old!
Does anyone recognise the mids I'm using? If you wanna do open baffle 3-ways, you oughta know because this one is an absolute honey. A clue: It's Danish.
Joe R.
tbla said:hey joe......![]()
i just want you to know that your contribution to this forum is top notch.......say - are you from denmark....?
btw....everybody is top notch (did i forget some...?)
What can I say?
Yep, Danish, but Aussie resident. Wife is Sicilian, so that makes our three boys Bavarian? That's the half-way point, isn't it? 🙄
Still have a Danish passport. Came out in my early teens with my parents. My Dad was a big-wig at DR (that's the Danish BBC, for those that don't know), being the boss of 'Dubbing' (Sound Department). He had long service leave, and wanted to taste what life was like Down Under.
Hey Nuuk, this oughta impress you:
I was born in the inner city Copenhagen suburb of Frederiksberg, no more than 2 kilometres away from the one and only original Carlsberg Brewery!
Joe R.
for Joe 😉 :
speaking of Scandinavian spks,what ya think about old SS 21W38 and D38 drivers?
hehe,I found them in old ITT boxes,probably OEM made from SS,with typical aperiodic box construction and series xover...........
cheers!
ps.as I can see-you're welcomed at RAT..........
cheers!
Hi
Protos
The GC's are pretty fresh out of the box 🙂)
I built a none buffered version trying to leave room for a valve stage.
The GC's in standard form are great, although they can be a little ruthless with some music in the high frequency.
Having built Joe's buffered version this has smoothed dramatically,but remains very fine in detail..
The mid and treble are very valve like,perhaps a little more extended in HF.Where they out perform the 2A3 is in both bass extension and control.I have just fitted a 50K DACT to the controller so the sound is changing all of the time.
They are built around basic parts using panasonic FC caps for power supply,and polyprops elswhere..Resistors at the momment are all metal film,I rather get to know the sound this way and maybe tweak in the future..
I am also trying various LPF caps, currently using 680pf the sound is great.
Pics are here http://www.petemoore.pwp.blueyonder.co.uk/music/
Peter
Protos
Peter
a few general questions
What sort of DC can the LM3886 withstand on its inputs? What is the symbol used in the datasheet for this parameter?
And does it amplify any input DC across its outputs?
And when an opamp's datasheet shows Vin+ and Vin- terminals, does that imply it will take a balanced input direct to those terminals?
Thanks for any help,
Grant
Grant
Re: a few general questions
If I remember corectly-I downloaded OP cookbook from TI site.
there you have plenty of info .
if TI site is not correct target for ya,try little googlin' for "OP cookbook"
cheers!
nowater said:What sort of DC can the LM3886 withstand on its inputs? What is the symbol used in the datasheet for this parameter?
Grant
cheers!
Yes, it will than function as a summing opamp, balanced in, unbalanced out.
Cheers,😉
Cheers,😉
From the datasheet: common mode input voltage < 80v, differential < 60v. Of course it amplifies dc across the inputs. It will take a balanced input but not directly. And it will need to have a negative feedback if used as amplifier. Maybe you should read a book on opamps. These questions hint at the possibility of smoke around your opamp projects 🙂
Thanks for your tips. Why won't it take a balanced input directly? Is it because the balanced input must first be averaged to ground to prevent amplified DC on the opamp's output?
Grant
Hi Nowater,
for answers to the questions have, plus many more answers to the ones you have not yet thought of here.
http://www.amazon.co.uk/exec/obidos...18354/sr=2-1/ref=sr_2_1_1/026-8874008-4365233
There may be other alternatives but this one is cheap & easy to read. amazon may not be the best source but this link is a starting point.
cheers
mike
cheers
mike
- Chip Amps
- Tube with Power IC Output Stage - JLTi
