True Wireless Stereo (TWS) Bluetooth for Speakers
https://www.arylic.com/products/up2stream-amp-mono-board
Not the most frugal of approaches, and I mostly just used these boards with Wi-Fi not Bluetooth.
I've not used this particular board, but have used both the non-amplified and amplified 2 and 2.1 channel versions.
It seems that you can select Stereo or L or R from the android 4Stream app that controls the devices.
They have DSP, tho it's another $20 for the software. Currently, there is no ability to control delay, but after having asked, it seems that might arrive in the future.
Integrates with some Wi-Fi streaming schemes as well.
The arylic forum is pretty good with support.
To program the CSR series chip you need to use either of the following board and the software tool to configure the boards. But for apt-x and above you need codes that’s will enable the feature.
You can get the configuration software link on tinyosshop
https://www.tinyosshop.com/index.php?route=product/product&product_id=876
https://www.digikey.com/en/products/detail/qualcomm/DK-USB-SPI-10225-1A/5269739
Can I use that to reprogram the name of this "CSRA64125 TWS" V. 1+ ?
Just a thought - why not look at microchip modules they are available on all major distributors digikey , mouser. And FCC approved for major countries and all tools openly shared by manufacturer
I m not taking sides but I read that CSR thread and so the issue everyone is going through.
I accidentally "fried" one of my two CSRA64125 TWS receiver boards. Where can I get another one (or an alternative with TWS) quickly to EU (Denmark) ? It is connected to a seperate amplifier
