no luck! went to buy the so called panzerholz... turned out to be some kind of African wood! Ho man! and the guy was like , ho no, I assure you, it is Delignit, Panzerholz I know what I´m talking about bla bla..., so I took a piece in my hand and broke it to pieces in front of his face. piece of Sh@@@t
I think there are some few topics at hand
Mechanical transmitted vibrations
There was a video some time ago, I think by Jack Oclee-Brown of Kef, where they looked closely into where the cabinet induced distortions come from. They found that by far it is from mechanically transmitted vibrations from the loudspeaker driver chassis, they found almost nothing coming from the airwaves inside the cabinet.
I assume then by far the most important things are the baffle itself and loudspeaker driver decoupling. Using 45mm Panzerholz for baffle would leave not much chance for vibrations I assume.
I have tried to see how driver decoupling is done, but found close to nothing, other than that Peter Gansterer of Vienna Acoustics uses floating silicone for tweeter, mainly to reduce feedback vibrations from baffle to tweeter...
Then the question I guess is, how much do we need for cabinet walls?
I assume then 45mm for baffle and 25 mm for cabinet walls is way good?
(But Noel only has 45 mm)
Felt on baffle
There are those guys who swear to using lots of felt... Duntech, John Dunlavy, others and I seriously believe this could have an effect, I guess it will also have an effect on response so x-over must be tweaked?
Some of the visual designs I like a lot are the older Audio Physic, like the Caldera 3 here, (Currently I have Audio Phsyic Avanti III)
Felt on baffle
Vandersteen, looks familiar
I auditioned the Vandersteen Treo, looks quite similar to the quattro above, but finish..... looks pretty crappy, like a second grade diy project
Perfomance wise IO was not impressed, lack of life, no magic, anemic ....
my favorite so far
That's Kaiser, yes?
FM Acoustics looks over the edge IMHO, as well as the price
what a sh$#$bag, sorry to hear
noamgeller,
On the brighter side, maybe your next speakers will be lighter (no Panzerholz), and less stress on your back...!
Jokes aside, must have been disappointing for you. Good luck with finding something suitable.
noamgeller,
It looks like compromize is non-existing within this thread!
I have been thinking of doing something completely different really... taking the top two drivers of the CNO-4 and add one or two more of the W18NX003 in the current typical audio physic style setup, making the baffle really narrow, like the Cardeas I already showed above ... but then there will be some tough crossover work that may be way beyond my capabilities
Guys, thanks for the compassion but I'm off the boat completely. I am going to build The Loudspeaker 1. No more CNO4 for me... Just how do I get this speaker good looking is beyond me. Any suggestions?
The Verity Audio style?
Ouch, not a design bomb no
Yes, I know... But alas... Suppose to be the very best, and already found few drivers on the used Market hence... But on the esthetic side =a nightmare
Yes, it re-establishes the cliche of Loudspeaker looking like a big fridge
Not sure how to do a big square box looking good?
- Troels Gravesen Ellipticor-3
