Thank you!I use Purifi PTT6.5M for midrange in open baffle. But as great as this driver is, it should not be crossed higher than 2000 Hz, since their front and back waves start to be different at around 1800 Hz. Luckily I have a good AMT for tweeter and also use the current drive amplifier to drive it, so 1800 Hz LR4 crossover is durable, though not as perfect as I want.
Lowering the xo to 2 or 1.8kHz wouldn't be an issue. Right now I cross the 8PE21 to the TPL at 1.1kHz. The TPL is great until about 13kHz, then drops fast. So I would probably later change to another, smaller, ribbon or plannar tweeter, than matches well to the chosen midrange. I do want to go top-notch midrange, though.
How wide of a baffle are you using your PTT6.5M in, and what's the lower xo point you use?
BTW, which AMT tweeter are you using?
I'm using 8x 6.5" woofers per side on a SLOB config, like xrk971 has done in his XSD speaker, which works very well up to 470Hz. Plenty of flexibility to integrate midbas to midrange, I think. The SLOB config works really well. The vibration-canceling effect is not to be minimized, nor the sense of impact the slot loading brings to the table.Hello,
400-3000Hz ? a 5" will do a better job rather a 6" ? A ptt5.25 or ptt4.0 or a 5n160 etc. plenty of choices
Best OB mid ? depend on its integration with the low mid and tweeter. I think the big challenge is this integrate seamless the midrange.
I use Mundorf AMT 25D1.1 for tweeter.
I use no baffle for PTT6.5M, instead mounting it to open frame using spring. I borrow the idea from one company in Netherlands. Mounting it in no-baffle help extend the dipole effect to higher frequency.
Great info!Yes, in my measurements both of these were excellent as a nude dipole midrange. These both have similar response to the rear as to the front, up to about 1.5k to 2k. The SB17MFC had usable response all the way up to breakup (around 4-5kHz, which was very unique and allows a bit higher crossover point to the tweeter while retaining a good pattern both in front and in rear.
Sid you get to listen to them, how were they different and which sound did you prefer?
I am probably going to use a small baffle. I've done 8PE21 nude but was a bit awkward-looking and I didn't hear much of a difference vs using them on a 30cm wide baffle (what I'm using now).
Nice!I use Mundorf AMT 25D1.1 for tweeter.
https://en.wikipedia.org/wiki/Netherlands
This is actually a a nude design I could live with. Are you using 1, 2, or 4 PTT6.5M per side? And how low do you cross them?
I use only one PTT6.5M for midrange from 350Hz-1800Hz. For 120Hz-350Hz is Scan Speak 26W/4867. For 50Hz-120Hz is 2x Faital Pro 12RS430 in V-Frame like LX521. For frequency from 10-50Hz, there are 2x sealed subwoofers with SB Acoustics SB34SWPL (20-50 Hz). My system is basically a beef-up and no-baffle Linkwitz LX521 and two sealed subs.
But right now I have a plan to revise it to get rid of a dip at 180 Hz due to ground bounce.
Ok I understand better 🙂 Yes you have plenty possibilities to test multiple midrange and find the good one 🙂I'm using 8x 6.5" woofers per side on a SLOB config, like xrk971 has done in his XSD speaker, which works very well up to 470Hz. Plenty of flexibility to integrate midbas to midrange, I think. The SLOB config works really well. The vibration-canceling effect is not to be minimized, nor the sense of impact the slot loading brings to the table.
@jerome69
Nevertheless, your point about not needing a 6.5" mid is a good one. Trung224 is using the 6.5" from 350Hz nude, so the 5" might work well from 450-ish. But then I wonder about the size of the motor and the backwave behavior, while with the PTT6.5M I can have certainty it works well from work done by others.
I think 5" midrange does not cut it in dipole if you crossed at 450-ish. Linkwitz and John.K used a 4" midrange from 1000 Hz, and Sd of them is around 40 cm2. So, it is ok to use a 6.5" midrange with 132m2 of Sd from 350Hz. A 5" midrange like 120mid_vhe with just 55cm2 of Sd IMHO should not be used at 450Hz on dipole design.
Wow, you cross over a Mundorf AMT 25D1.1 at 1.8 kHz??? That is really using it right to the edge (based on the distortion plots in the datasheet)!I use only one PTT6.5M for midrange from 350Hz-1800Hz. For 120Hz-350Hz is Scan Speak 26W/4867. For 50Hz-120Hz is 2x Faital Pro 12RS430 in V-Frame like LX521. For frequency from 10-50Hz, there are 2x sealed subwoofers with SB Acoustics SB34SWPL (20-50 Hz). My system is basically a beef-up and no-baffle Linkwitz LX521 and two sealed subs.
@CharlieLaub : You are right, it is right to the edge. That is still my least satisfying thing in my dipole systems, alongside with a dip due to ground bounce at 180Hz. I use LR4 crossover and a current drive amplifier for it, and it is only still acceptable level for me.
Not on topic, but what do you think a best way to get rid of 180Hz dip? I think try to place the 10" lower mid driver to bottom but have a difficulty of placing the dipole V-Frame on top of it.
Regarding the dip... My most recent designs are 3-way dipole plus sealed subwoofer(s). The dipole part is designed to minimize the floor bounce like this:
I ignore any floor bounce effect from the midrange (I just measure its response in a quasi free field type way, far above the ground). This is because (I believe) that our hearing system is designed to recognize a source at some height above the ground and at higher frequencies and will sort of "compensate" for any floor bounce effect as part of the natural hearing process. This is different at lower frequencies like for the woofer.
This type of driver arrangement seems to integrate very well at most any distance. I like that I can "tune" the sealed subwoofer Q and Fb using a Linkwitz Transform so that the low frequency bass energy sounds correct and I still get the nice low end of a monopole. I think this is not too different from the setup that @Juhazi uses for his speakers, with some differences in how he implements the woofer section.
I will definitely build more speakers using the above concept.
- The woofers are used from 60Hz or 70Hz to 350Hz. I use multiple smaller drivers, typically four 8" or 10". There are two pairs per side. Each pair is in a relatively small baffle, for example for 8" drivers the baffle might measure 12" high by 24" wide. The two pairs are placed (as viewed from the listening location) on the floor and are separated in the front-back direction by about 12-14 inches (see attached pic). By placing the drivers very close to the floor like this the floor bounce cancellation can be moved up in frequency above 350 Hz so that it is out of band. By using four drivers I get more Sd*Xmax swept area. Because the baffle area is not enough for these drivers to deliver high SPL below 40Hz, I use the sealed subwoofer for the lowest notes.
- There is a single midrange operating from 350Hz to as high as I can take it, which is usually no more than about 2kHz. The midrange is used nude, about 30 inches or slightly more above the floor.
- The tweeter (a dipole AMT type) is also used nude and located directly above and as close to the midrange as possible.
I built two planar line array systems that both work very well. One of the systems uses the LM8K, floor to ceiling, the other uses two 600mm long planar drivers per side for a 1.2M line length. Both systems cross below 400Hz to a dipole bass section.Thank you!
Will look into this one.
Did you happen to test any of the large plannars among that dozen of drivers you tested? In case you didn't, why weren't they included?
A single small planar driver does not have sufficient displacement to achieve your desired crossover point.
There is no such rule where to high pass the mids in OB.I think 5" midrange does not cut it in dipole if you crossed at 450-ish. Linkwitz and John.K used a 4" midrange from 1000 Hz, and Sd of them is around 40 cm2. So, it is ok to use a 6.5" midrange with 132m2 of Sd from 350Hz. A 5" midrange like 120mid_vhe with just 55cm2 of Sd IMHO should not be used at 450Hz on dipole design.
It is very depend of baffle size, distortion and sensitivity of drivers. It is always good to have mids and woofers with higher sensitivity than tweeters.
If, for example, pro 6,5 mid has 6-8 dB higher sensitivity than tweeter, in combination with dipole first peak, there is around 10 dB less bottom boost needed.
I used 18 sound 6ND430 (on very small baffle) in MTM down to 180Hz, and now using single, naked Sica 8FE2.5CP from 170 Hz.
Even on highest levels cone movement is around 4 mm p-p and on normal listening levels is barely noticeable and measured distortion is very low.
Thank you! That's a very good reference!I built two planar line array systems that both work very well. One of the systems uses the LM8K, floor to ceiling, the other uses two 600mm long planar drivers per side for a 1.2M line length. Both systems cross below 400Hz to a dipole bass section.
I'm intrigued by Igor Levitsky's design. He has been designing plannars for many years, designed the Radian line-up, and designed Consonus Tide (https://www.consonusaudio.com/products) using his LM10n and LT3 crossed at 250 and 2.2kHz. I watched YouTube "reports" from folks visiting audio shows who heard the Tide and seemed to be impressed.
Also, member Juhazi uses a similar configuration, and the "Circles of doom" design a while back used plannar midrange and tweeter in OB.
Given above references and the fact plannars have a great front to back symmetry, I couldn't help but wonder why so many knowledgeable folks contributing to this thread hadn't at least tested plannars. Now I do. Thanks for the input!
BTW, I'm reading through materials for the suggested drivers. So far I have deprioritized the Mark Alpair 10p as HiFiCompass shows distortion well above what the Purifi or SB17MFC35-4 display. The Kartesian looks interesting but not as much info/tests available. Same for BMS 6N160. If anybody happens to know where I can find testing info for these, I would appreciate it.
- Top midrange drivers for open baffle?
