Top midrange drivers for open baffle?
I use Purifi PTT6.5M for midrange in open baffle. But as great as this driver is, it should not be crossed higher than 2000 Hz, since their front and back waves start to be different at around 1800 Hz. Luckily I have a good AMT for tweeter and also use the current drive amplifier to drive it, so 1800 Hz LR4 crossover is durable, though not as perfect as I want.
Thank you!
Lowering the xo to 2 or 1.8kHz wouldn't be an issue. Right now I cross the 8PE21 to the TPL at 1.1kHz. The TPL is great until about 13kHz, then drops fast. So I would probably later change to another, smaller, ribbon or plannar tweeter, than matches well to the chosen midrange. I do want to go top-notch midrange, though.
How wide of a baffle are you using your PTT6.5M in, and what's the lower xo point you use?
BTW, which AMT tweeter are you using?
Hello,
400-3000Hz ? a 5" will do a better job rather a 6" ? A ptt5.25 or ptt4.0 or a 5n160 etc. plenty of choices
Best OB mid ? depend on its integration with the low mid and tweeter. I think the big challenge is this integrate seamless the midrange.
I'm using 8x 6.5" woofers per side on a SLOB config, like xrk971 has done in his XSD speaker, which works very well up to 470Hz. Plenty of flexibility to integrate midbas to midrange, I think. The SLOB config works really well. The vibration-canceling effect is not to be minimized, nor the sense of impact the slot loading brings to the table.
Reactions: Vix
I use Mundorf AMT 25D1.1 for tweeter.
I use no baffle for PTT6.5M, instead mounting it to open frame using spring. I borrow the idea from one company in Netherlands. Mounting it in no-baffle help extend the dipole effect to higher frequency.
Yes, in my measurements both of these were excellent as a nude dipole midrange. These both have similar response to the rear as to the front, up to about 1.5k to 2k. The SB17MFC had usable response all the way up to breakup (around 4-5kHz, which was very unique and allows a bit higher crossover point to the tweeter while retaining a good pattern both in front and in rear.
Great info!
Sid you get to listen to them, how were they different and which sound did you prefer?
I am probably going to use a small baffle. I've done 8PE21 nude but was a bit awkward-looking and I didn't hear much of a difference vs using them on a 30cm wide baffle (what I'm using now).
I use only one PTT6.5M for midrange from 350Hz-1800Hz. For 120Hz-350Hz is Scan Speak 26W/4867. For 50Hz-120Hz is 2x Faital Pro 12RS430 in V-Frame like LX521. For frequency from 10-50Hz, there are 2x sealed subwoofers with SB Acoustics SB34SWPL (20-50 Hz). My system is basically a beef-up and no-baffle Linkwitz LX521 and two sealed subs.
But right now I have a plan to revise it to get rid of a dip at 180 Hz due to ground bounce.
Ok I understand better 🙂 Yes you have plenty possibilities to test multiple midrange and find the good one 🙂
@jerome69
Nevertheless, your point about not needing a 6.5" mid is a good one. Trung224 is using the 6.5" from 350Hz nude, so the 5" might work well from 450-ish. But then I wonder about the size of the motor and the backwave behavior, while with the PTT6.5M I can have certainty it works well from work done by others.
I think 5" midrange does not cut it in dipole if you crossed at 450-ish. Linkwitz and John.K used a 4" midrange from 1000 Hz, and Sd of them is around 40 cm2. So, it is ok to use a 6.5" midrange with 132m2 of Sd from 350Hz. A 5" midrange like 120mid_vhe with just 55cm2 of Sd IMHO should not be used at 450Hz on dipole design.
Reactions: LewinskiH01
Wow, you cross over a Mundorf AMT 25D1.1 at 1.8 kHz??? That is really using it right to the edge (based on the distortion plots in the datasheet)!
Reactions: trung224
@CharlieLaub : You are right, it is right to the edge. That is still my least satisfying thing in my dipole systems, alongside with a dip due to ground bounce at 180Hz. I use LR4 crossover and a current drive amplifier for it, and it is only still acceptable level for me.
Not on topic, but what do you think a best way to get rid of 180Hz dip? I think try to place the 10" lower mid driver to bottom but have a difficulty of placing the dipole V-Frame on top of it.
Regarding the dip... My most recent designs are 3-way dipole plus sealed subwoofer(s). The dipole part is designed to minimize the floor bounce like this:
  • The woofers are used from 60Hz or 70Hz to 350Hz. I use multiple smaller drivers, typically four 8" or 10". There are two pairs per side. Each pair is in a relatively small baffle, for example for 8" drivers the baffle might measure 12" high by 24" wide. The two pairs are placed (as viewed from the listening location) on the floor and are separated in the front-back direction by about 12-14 inches (see attached pic). By placing the drivers very close to the floor like this the floor bounce cancellation can be moved up in frequency above 350 Hz so that it is out of band. By using four drivers I get more Sd*Xmax swept area. Because the baffle area is not enough for these drivers to deliver high SPL below 40Hz, I use the sealed subwoofer for the lowest notes.
  • There is a single midrange operating from 350Hz to as high as I can take it, which is usually no more than about 2kHz. The midrange is used nude, about 30 inches or slightly more above the floor.
  • The tweeter (a dipole AMT type) is also used nude and located directly above and as close to the midrange as possible.
With this sort of "compound dipole" woofer setup, if you measure the response at 3m (e.g. outdoors) on the ground and then about 40" above ground (typical listening height) the response looks identical except at 40" the SPL is about 1.5dB lower. There is a wide dip in the response around 500Hz or so IIRC that limits the upper frequency for the woofers, and this is why I cross over somewhere around 300-350Hz.
I ignore any floor bounce effect from the midrange (I just measure its response in a quasi free field type way, far above the ground). This is because (I believe) that our hearing system is designed to recognize a source at some height above the ground and at higher frequencies and will sort of "compensate" for any floor bounce effect as part of the natural hearing process. This is different at lower frequencies like for the woofer.
This type of driver arrangement seems to integrate very well at most any distance. I like that I can "tune" the sealed subwoofer Q and Fb using a Linkwitz Transform so that the low frequency bass energy sounds correct and I still get the nice low end of a monopole. I think this is not too different from the setup that @Juhazi uses for his speakers, with some differences in how he implements the woofer section.
I will definitely build more speakers using the above concept.
Thank you!
Will look into this one.
Did you happen to test any of the large plannars among that dozen of drivers you tested? In case you didn't, why weren't they included?
I built two planar line array systems that both work very well. One of the systems uses the LM8K, floor to ceiling, the other uses two 600mm long planar drivers per side for a 1.2M line length. Both systems cross below 400Hz to a dipole bass section.
A single small planar driver does not have sufficient displacement to achieve your desired crossover point.
There is no such rule where to high pass the mids in OB.
It is very depend of baffle size, distortion and sensitivity of drivers. It is always good to have mids and woofers with higher sensitivity than tweeters.
If, for example, pro 6,5 mid has 6-8 dB higher sensitivity than tweeter, in combination with dipole first peak, there is around 10 dB less bottom boost needed.
I used 18 sound 6ND430 (on very small baffle) in MTM down to 180Hz, and now using single, naked Sica 8FE2.5CP from 170 Hz.
Even on highest levels cone movement is around 4 mm p-p and on normal listening levels is barely noticeable and measured distortion is very low.
Thank you! That's a very good reference!
I'm intrigued by Igor Levitsky's design. He has been designing plannars for many years, designed the Radian line-up, and designed Consonus Tide (https://www.consonusaudio.com/products) using his LM10n and LT3 crossed at 250 and 2.2kHz. I watched YouTube "reports" from folks visiting audio shows who heard the Tide and seemed to be impressed.
Also, member Juhazi uses a similar configuration, and the "Circles of doom" design a while back used plannar midrange and tweeter in OB.
Given above references and the fact plannars have a great front to back symmetry, I couldn't help but wonder why so many knowledgeable folks contributing to this thread hadn't at least tested plannars. Now I do. Thanks for the input!
BTW, I'm reading through materials for the suggested drivers. So far I have deprioritized the Mark Alpair 10p as HiFiCompass shows distortion well above what the Purifi or SB17MFC35-4 display. The Kartesian looks interesting but not as much info/tests available. Same for BMS 6N160. If anybody happens to know where I can find testing info for these, I would appreciate it.
While I agree with your assessment about choosing driver based on baffle size, distortion and sensitivity of drivers, your example is not contradict to my opinion. For example, 6DN430 have Sd of 133 cm2, so in MTM the total Sd of them is 266 cm2, which is equivalent to a 10" driver, so of course more than enough for crossing at 180 Hz with very small baffle. Your Sica 8FE2.5CP have Sd of 213 cm2, so it is ok to use them from 170Hz.
If the goals is just open baffle then 5" is fine with wide enough baffle, but if the goals is dipole, which means as small as possible baffle for midrange/tweeter then 5" driver is not enough for 450Hz cut down. 600 -700 Hz crossover is more suitable.
There's always the Bliesma M142A, which has a huge advantage as a OB mid due to its highly unrestricted rear chassis. The rear emitted sound is very even and balanced. Its not cheap at about $1000/pc, but IMO one of the best current OB mids available.
The problem with the 8PE21 is its very low Qts, making it weak in lower mid output. It is however an excellent cone mid. As with any larger mid playing too high above 8ts the upper cutoff.
The 8MDN51 is a great 8" cone mid. So is the 8NDL51. I like the Audax HM170CO for all sort of midrange applications, even OB. The midrange upper end is excellent up past 4k with its highly controlled, gradual breakup and good sensitivity. You can also consider the SB 6MW150D and the Peerless NE180W.
Reactions: Abbiendi and swak
Thank you!
I think you should focus on what kinds of dispersion you like, wide or low directivity. Then choose the driver and crossover point to create the even, smooth off-axis response.
I prefer wide directivity and constant directivity as high as possible now, so I use an AMT without a waveguide. I also want somewhat decent vertical dispersion, so I chose a mid-size AMT—specifically, the Mundorf 25D1.1. This AMT driver can be used down to 2000 Hz without stress. For the midrange, I selected the PTT6.5M because it has very low distortion, decent Xmax, and a great motor, making it suitable for use without a baffle. It also has a similar front-to-back dispersion up to around 1600–1800 Hz.
I chose an 1800 Hz crossover point because, at that frequency, the 30° and 45° off-axis response of the PTT6.5M is within 2 dB of its on-axis response. This makes it a decent match for the 30° and 45° off-axis response of the 25D1.1, which has only a 1 dB difference from its on-axis response. Of course, this puts some stress on the AMT driver, but I can somewhat mitigate the issue by using an LR4 crossover. It's a compromise, but one I'm willing to make.
If you like low directivity, then an AMT with waveguide as tweeter is needed. If your waveguide is 8" wide like the waveguide in your TPL150H now, then a 8" midrange like TD8M is possibly a better choice than a 6.5" driver like PTT6.5M. If your waveguide is 6.5" wide then you can use PTT6.5M.
There's always the Bliesma M142A, which has a huge advantage as a OB mid due to its highly unrestricted rear chassis. The rear emitted sound is very even and balanced. Its not cheap at about $1000/pc, but IMO one of the best current OB mids avaiavailable.
Are you saying this from first hand experience?
I toyed with the M142, aluminum or texTreme. Of course it's expensive but not necessarily out of reach. I exchanged with a member here who has experience with this and other Bliesma drivers, and while he thinks very highly of them, he didn’t think the M142 would be great in OB. Paying top price and not getting top dipole performance didn't come across as fully compelling.
I also exchanged with Bliesma and they said the driver works well in OB but couldn't share more info.
Bliesma provides front and back side responses in their product literature:
We can see that off-axis the back side response drops fast post 1.3kHz or so.
You can see I did consider the driver, but didn’t get to convince myself the performance was worth the price. I have not heard it, though. Hopefully your statement is from first-hand experience and I would be very interested in your thoughts (as well as anybody else who heard these).
