stimmedmarine, american man who win the lao kaen competition in Northeast of thailand(isan). he plays very good. haha i can't..
Lai Khaen Master All Modes ??? ??? Khene Lao by Jonny Olsen - YouTube
and this wot that i mention.
http://www.youtube.com/watch?v=xyDIBnPmhpM
very surprise when i see the jbell pic. why the dimensions are difference when compare from me. i did sketch from the xoc1 plan. who know the difference? but ok when play today. the bass is soft.
Hi Thawach
What you have built is not a jbell SS15 but an early attempt by me, to meet jbells Single Sheet Challenge. The Cube shape was rejected, and a rectangular profile as used, with a different fold to increase the path length.
Here is a link to the SS15 plans.
http://www.diyaudio.com/forums/atta...th-challenge-singlesheet_2_2010_aug18_dwg.pdf
http://www.diyaudio.com/forums/atta...challenge-2011_mar12_ss15_profile_revised.pdf
As you say with this cube TH plan, the bass is 'Soft' but the mid bass, I hope, is 'Loud'
The photo you have posted of jbells TH cabinets is another bigger design
http://www.diyaudio.com/forums/subwoofers/127908-jbells-set-four-tapped-horns.html
Kind Regards
Martin (Xoc1)
Kind Regards
Martin (Xoc1)
Hi Thawach,
This is a link to the drawing version with metric dimensions, "Single sheet TH challenge" Post #82:
http://www.diyaudio.com/forums/subwoofers/170771-single-sheet-th-challenge-9.html
Hi Thawach
Kind Regards
Martin (Xoc1)
i measured the path length again in last week. and simed it. okay i like the mini cube. but my friend seems loss his feeling a little when i tell that's not Jbell. i sim with the e15-300S. and think all the thing will ok. -3db @ 50-55 hz i feel satisfy this cab.thanks martin
Hi Thawach,
ive just been downloading. all my friends seem like the tapped horn in pa. many designs from me now they seem don't like. they only want the tapped horn design. they never listened the TH before when someone built. they listened and like it. two plans ill waiting someone to build. thanks tb
just measure 0.5 tsw-218 today. use the P audio P180/2242 new series. i try to use the simple sysrta to measure. ok it looks good but only freeware. the box only paint wood primer one time and still paint it again.
@martin, i'm surprise about the cube th plan. why to use the 12 mm mdf thick. strong enough? and another Q i want to know u use any dsp brand to cut off the low freq problem of the tapped horn. thank u
my friends like the light weight if 12 drv can use the 12 mm. i think bracing a lot. ok the 12 mm may be good.
hey sir Thawach am think of doin a pair of double hd but would like to get it a little bigger so i can put a pair of mt 121 mids in top (508h x 1168.4w x 660.4d) was think about speaker i want to use is the 18sound 15w700 15W700 - LF Ferrite Driver can i get any help with the design???an advice to do the curve setion with eighter 12mm or 18mm plywood ....
thanks
thanks
thanks
apology friend i don't have a free time to answer u. double hd i don't sure if adjust the dimension for mt121 ill get the best result from it. if u don't have any other design u can tell me if i have a free time i will try it.
thank you very much for all the info! Khop Khun Kap! I looked up the locations on google maps. sorry to hear about the floods..I saw on tv, no good. I plan to go to Chang Mai, maybe I will visit your hometown on the way.
take care
Will
bill this year no have the flood, i have the pics when p audio can solved the promblem.
this video when mbp46 played job. 4 bins in a stack per side. the music from pc com. i don't sure my friend brought the dancer from there? LOL they look funny.
http://www.youtube.com/watch?v=k1Kk5T2lV_g
these pics about 15 mbp46 built installed p audio e15-300s new series. they work great more than the size. hp cut off about 40 hz
these video about tested 15 mbp46 and compare with cube TH and Niranjana bass bin that i designed for e15-300es tested from many songs and difference because difference for the users.
Cube TH - YouTube
Cube TH karaoke - YouTube
15 inch MBP46 - YouTube
15 inch MBP46 with karaoke song - YouTube
Nirajana subwoofer - YouTube
and TL Tested in the same time
?? - ??? ???????? - YouTube
Cube TH - YouTube
- Subwoofers
- TL sub project
