TL sub project
a few days . started to build the jbell tapped horn. the pics when started.
Hi Thawach
What you have built is not a jbell SS15 but an early attempt by me, to meet jbells Single Sheet Challenge. The Cube shape was rejected, and a rectangular profile as used, with a different fold to increase the path length.
Here is a link to the SS15 plans.
http://www.diyaudio.com/forums/atta...th-challenge-singlesheet_2_2010_aug18_dwg.pdf
http://www.diyaudio.com/forums/atta...challenge-2011_mar12_ss15_profile_revised.pdf
As you say with this cube TH plan, the bass is 'Soft' but the mid bass, I hope, is 'Loud'
The photo you have posted of jbells TH cabinets is another bigger design
http://www.diyaudio.com/forums/subwoofers/127908-jbells-set-four-tapped-horns.html
Kind Regards
Martin (Xoc1)
Hi Thawach
Kind Regards
Martin (Xoc1)
i measured the path length again in last week. and simed it. okay i like the mini cube. but my friend seems loss his feeling a little when i tell that's not Jbell. i sim with the e15-300S. and think all the thing will ok. -3db @ 50-55 hz i feel satisfy this cab.thanks martin
Hi Thawach,
This is a link to the drawing version with metric dimensions, "Single sheet TH challenge" Post #82:
http://www.diyaudio.com/forums/subwoofers/170771-single-sheet-th-challenge-9.html
ive just been downloading. all my friends seem like the tapped horn in pa. many designs from me now they seem don't like. they only want the tapped horn design. they never listened the TH before when someone built. they listened and like it. two plans ill waiting someone to build. thanks tb
hey sir Thawach am think of doin a pair of double hd but would like to get it a little bigger so i can put a pair of mt 121 mids in top (508h x 1168.4w x 660.4d) was think about speaker i want to use is the 18sound 15w700 15W700 - LF Ferrite Driver can i get any help with the design???an advice to do the curve setion with eighter 12mm or 18mm plywood ....
thanks
thanks
apology friend i don't have a free time to answer u. double hd i don't sure if adjust the dimension for mt121 ill get the best result from it. if u don't have any other design u can tell me if i have a free time i will try it.
my friend just did measure last week. installed the c18-650el new series when measured it but this bin can install c18-650el old series,it works well as the same.
