Yes, actually you're right. They dropped the price recently and still kept the 50% discount.Whoa. I could have sworn last I checked they were $250... interesting. TI is now competing with the diy modules.
Anyway, I picked one up myself. Soon enough I shall amaze you all with my fantastic enclosure-building skills.
TI still lets you put in for an order at the reduced price. I put in the order for the TPA3255EVM yesterday. Who knows when it will come. I am not in a big rush at the moment.
yes- they let you order and then will cancel in a couple days. I've tried with each module.
strange!
any details which regulations were that critical?
"Due to changes of EU legislature some of the EVMs have to be re-certified before they can be exported again from US to EU, which is a long bureaucratic procedure."
No more info then this.
Well then, I guess I won't count on the order actually happening.
tpa3255 and tpa3251d2evm are out of stock... Damn it!
Do they still have the tpa3251d2evm? My link from my purchase history did not work, and I could not find it. Was thinking at the reduced price get another and run it mono. Altough, without any experience in it at stereo yet not sure what, other than more power I would gain, as it already has more than enough, but it's the thought that counts.
A Belgian member here got his boards early-mid September? What dramatic change has happened in eu legislature in less than 2 weeks? Bulls*%/t
i received two 3255 boards in the UK a couple of weeks ago.. and last time i checked the UK is still a member of the EU....
Maybe TI thinks with brexit they can ignore some things 😉
Any way try ordering, just check if your order shipment date is less then one year. If no just cancel order. Maybe only Poland was unlucky.
Shipping date
I ordered mine on 09/20 and was informed the shipping date is 12/29/17. They staid it was due to being out of stock.
As I read the TPA3244EVM application note I see that the unit can operate in Single Ended output mode. Does this mean 4 channels of output? The picture shows banana jacks for inputs A,B,C, and D but for the output to the speaker there is only one set of grounds for A and B and one set of grounds for C and D. Would I simply double up the speaker cables for the black input or is there something more involved? Also any idea what the output power might be across the 4 channels. I would use the Meanwell LRS-350-48 as a SMPS.
Thanks,
JD
Thanks,
JD
Yes, in SE you'll have 4 Channels at half the power compared to BTL. Beside that, the outputs capacitor-decoupled and ground-referenced. Im using my TPA3255 in mixed mode, 1xBTL + 2xSE. SE works good for mid-highs.
PVDDmax for TPA3244 is 30V, so your 48V supply can't be used. Better choice: LRS-350-24 set at 28.8V.
Output power to except:
30W into 4R 10%
50W into 2R 10%
25W into 4R 1%
44W into 2R 1%
More than enough for mid-highs. You may consider using 1xBTL + 2xSE as well in a 2.1 configuration.
30W into 4R 10%
50W into 2R 10%
25W into 4R 1%
44W into 2R 1%
I've been listening to this TI TPA3255EVM for a few days now, and I had Stravinsky's "The Rite of Spring" playing (Reference Recordings, "Stravinsky", Eiji Oue and the Minnesota Orchestra). I didn't think I had the CD playing exceptionally loud--maybe 78dB--and yet my wife asked me to turn it down because she could hear the timpani strikes through the ceiling and into the upper floor of our townhome. She was concerned the neighbors might complain about the shaking.
Keep in mind I am playing this amp through KEF LS50 monitors with 5.25" mid-woofer drivers. I do not have a subwoofer, yet the bass is quite palpable. Impressive.
I just received this email from TI tonight. Clicking on the 3255 icon brings you to that 3255 EVB page where it says "order now" at the $150 price. The discount code in the email drops that to $75.
However I ordered one back on 9/21 and it still says "in work" with no delivery date when I check the order status.
I just ordered a 3255EVM. The product webpage indicated that they are out of stock, but after completing the ordering process, the "order receipt" page is showing it as in stock. We shall see, I guess.
Can you share the discount code please.
I believe it is still "highpoweraudio"
- Class D
- TI Class D EVM Board 50% Promotion
