solved the problem
hi,
thanks, i have solved the problem. it was cause by power supply line was too far away from 1000uf cap so now i made change the line to be more close and first power comes to the 1000uf cap then go to the power transistors. this is the way i solved the problem...now ok..
best regards
michael
hi,
best regards
michael
Our forum is not editing and not accepting image attachments
The problem appeared once again... a pitty that unstability we are having those last times.
Well...maybe my computer problem..... not absolutelly sure the problem is with our forum.
regards,
Carlos
regards,
Carlos
finally completed the Dx-turbo amp.
Dear Dx and all,
i have completed the Dx-Turbo amp. now really enjoying its sound so great.....
here is the picture of completed amp. i am using this two 8ohms speaker system for now so its become 4ohms, but not for long i will be using in 4ohms. sound really great.
i have taken the pic without the flash so can see how its lights are at night.
thanks to carlos for your great amp.
best regards
michael
Dear Dx and all,
best regards
michael
Looks real good Space. Looking at these pictures, the heatsink clearly resembles a King's crown. Royalty. You have built the King of the Dx amplifiers! Long live the DX!! Thanks for sharing.
best wishes,
Brian
best wishes,
Brian
My pleasure folks, to try schematics, to test circuits, to build them, to test them,
to publish them and to see folks building and feeling good.
This is all pleasure to me.... i love to contribute to forum folks and i love to build and listen those amplifiers, not only mine units, but i use to try other amplifiers too.
Now, the big spy, Charlie the Inspector, is building Doctor Bora circuits...always searching for good sounds, always listening and comparing and evaluating... this is pleasant to me... and the research is natural, something i have inside myself.... listening...always listening... i really do not bother to use instruments... have used them while i worked for Motorola, the VHF radios alignment had a lot of jigs and instruments...when i realised i could make 20 times faster and 5 times better listening i started the method to use "human instruments"
regards,
Carlos
regards,
Carlos
The forum is not editting my messages.
I do not know if this is forum problem or my problem.
Michael.... Space2000...thank you very much.
Send me full resolution (ALL) images you have...i want to feed the Orkut with good quality images...i have already 1500 images there...do not reduce a pixel please... send me the full images..full resolution.. the many megapixels ones saved into your memory card.
Picture shows my nephew James Mergulhão Green and Rebecca Mergulhão in UK.... they are brothers, the boy was kidnapped by his father when had 7 years old.... i have found him because i have posted IN OUR BELOVED FORUM, a message searching for him.
LONG LIFE TO OUR MAGNIFICENT FORUM!
Carlos
Carlos
The picture, dear folks, are my nephews in UK
James Mergulhão Green and Rebecca Mergulhão.... they are brothers.
I have found this nephew, the boy, a couple of years ago, and BECAUSE OUR BELOVED FORUM...i have left a message here searching for him.
He was kidnapped by his father when he was 7 years old... entered an airplane to London with School uniform, dressed that way.... then he never saw his mother once again... she died for Cancer....both guys does not have mother anymore... and the destiny have punished the man did bad thing too.
Long life to the forum!
Carlos
Carlos
What artistry. Thanks for sharing the pictures. If you have any of your power supply, I'd be interested in seeing how you did those as well.
Thanks for all the inspiration. You're truly a diy person and a credit to these forums.
best wishes,
Brian
best wishes,
Brian
Yes... Space is special... an artist.
Very nice ideas he uses to apply into his amplifiers.
I am happy he loves Dx Amplifiers...he is an excelent advertising man.
regards,
Carlos
regards,
Carlos
Hey space2000, I really love the way you have mounted the output devices and veroboard. 🙂
Maybe Nordic could develop a nice small PCB for that design, then it would look schmic indeed.
A question I have is ... do your prefer the DHR sound to the Aleph amp and the Mooly amp?
thanks
thanks
hi KLe,
This three amps are totally different sound then each other. Watts makes lots of different in playing music, like comparing single and multiple violins. More watts more violins to be add. So when you will listen high watts into low volume level its sound really great.
Molly amp, hi and low are ok but the mid is not sonic and the watts are low too so can’t compare with Dx. Dx- turbo have high watts with really define music sonic. Vocal Is nice too. To my view it is Very nice amp as class AB. Molly also a nice amp but those prefer to have low watts.
Aleph-A to Z any things, They are totally different then Dx or Molly (AB). Aleph is class A so sound normally gets more open and sonic then AB. Do not expect for every thing into one amp. Molly and Dx-turbo are really cold device, its don’t run hot. Easy to build and Other hand aleph is a shara Desart, african hot or whatever you can say regarding to Hot….Hot …hot….*** sound really Hot and worm too.. Aleph is not so easy to build.
Its choice to be made which should go…..i made all of them…
Thank you.
Thank you.
Great, Michael, great.
I had a hunch it would look like that, but it's nice to see stuff. Thanks for sharing.
best wishes,
Brian
best wishes,
Brian
first i have to Thanks to "Dx" for great amp. its sound really great.
hi guyes, made this Dx-turbo amp...you won't regret at all. you will enjoy every single bit of music. its easy to build and more stable. i am enjoying it everyday including my wife enjoying it too.
if i can build it...you should be able to make....don't afraid to build, just go ahead and do it, show it here, we will claps our hand.
best regards
michael
best regards
michael
hei uncle charly
i ve just seen the final dx turbo schematic,,,,,i think looks pretty nice and symetrical
question :
would you like to tell us why output resistors are 1 ohm ?
normaly 0.47 is the maximoum you see to circuits like that ....
also with proper psu whats the expected power ????
question :
- This is the DHR.... Dx High Resolution Turbo
