Here attached an image showing a way to connect TWTMC boards to Ian's boards (the first otion is showed).
Where I wrote "Xo adapter ???" means that we need Ian's support to understand what his adapter can accommodate. U.fl. connector if possible or direct soldering on XO adapter pads.
The document "Ian_Form_Example.pdf" is an example that show how to fill the document "TWTMC Parts Options & Assembly Service" provided from Phil.
Thank for the layout Andrea,
2 adapter types provided by the G.B of Ian
1 partagé sur ZimageZ
2 partagé sur ZimageZ
- andrea_mori : 5 x 5.6448MHz + 2 x 11.2896MHz + 3 X 22.5792 MHz + 3 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 90.3168 MHz + 1 x 98.304 MHz + 10 x PCB + 4 x daughter board PCB
- Eldam : 1 x 5.6448MHz + 1 X 22.5792 MHz + 1 x 24.576 MH + 2 x daughter board PCB + 4 x PCB
- esgigt : 1 x 11.2896 Mhz + 1 x PCB, soldered if possible
- fralippo : 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughter board PCB
- mravinsky : 2 x 11.2896 Mhz + 2 x XO PCB + 1 x Daughter board PCB
- TNT : 1x22.5792MHz 1x24.5760MHz + 2 x PCB, + 1 x daughter board, all soldered if possible
- 1audio : 2x22.5792MHz 2x24.5760MHz + 2 x PCB + daughter board.
- randytsuch : 1x22.5792MHz 1x24.5760MHz + 4 x PCB + 1 x daughterboard
- myint67 : 1x11.2896mhz ,1x22.5792,1x45.1584,1x49.152 ,4 PCB ,2xdaughter board , soldered if possible
- kf_tam : 2x PCB
- BDL : 1 x 11.2896 MHz + 4 x PCB + 1 x daughter board PCB
- thorstenlarsen : 2 x 11.2896 MHz + 2 x PCB
- Zoran : 1x22.5792MHz 1x24.5760MHz + 2 x PCB, (soldered or not...) + 1 x 11.2896 MHz + 1 x PCB
- walangalam : 1 x 11.2896 Mhz + 2 x PCB
- AR2: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB (soldering not needed)
- mcluxun: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughterboard (soldering if possible)
- damohpi: 1 x 11.2896 + 1x PCB unsoldered
- noizas : 2 x 5.6448MHz + 2 x 11.2896MHz + 4 x PCB
- badrisuper : : 1 x 11.2896 Mhz + 2 x PCB
- Clsidxxl: 1 x 45.1584 MHz + 1 x 49.152 MHz+daughter board + 2 x PCB -With Assembly Service
- zeta4 1x 22.5792Mhz + 1 x PCB (soldering not needed)
- hirez69: 1 x 22.5792 MHz and 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 4 x PCB (soldered) + 1 x daughter board
- palmito : 1 x 45.1584 MHz + 1 x 49.152 MHz; 1 x 22.5792MHz 1 x 24.5760MHz; 2 PCBs; 2 daughter boards.
- gentlevoice: 1 x 22.5792MHz + 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 1*PCB
- naimster: 1x 22.5792 MHz + 1x 24.576 MHz + 2x PCB + 1x daughterboard (soldered if possible)
- zenelectro : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB's + 1 x daughterboard (soldered if possible)
- Ryssen : 1 x 24.576 MHz + 1 x PCB soldered
- flowerpot : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- deanoUK : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- Miklos: 1 x 11.2896MHz + 2 x PCB + 1 x 16.9344 MHz
- Kannan_s:1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- Acko : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- tuyen : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB's + 1 x daughterboard (soldered if possible)
- Malvin : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- Marlowe: 3 x 16.9344Mhz + 3 x 25MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 22.5792 MHz + 1 x 24.576 MHz + 8 x PCB + 3 x daughter board PCB
- ppap64: 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board(soldered if possible)
- Superdad: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughter board (soldered if possible)
- vita:1 x 24.576Mhz + 6 PCB
- bkdog 1 x 90.3168 MHz + 1 x 98.304 MHz + 2 x PCB + 2 x daughter board (soldered if poss)
- ryanj 1 x 11.2896 Mhz + 1 PCB + 1 daughter PCB
- justubes 1 x 11.2896 Mhz
- kf_tam : 2x PCB
Im thinking about doing something like this for Ian's dual XO board:
Also Andrea will there be any performance degradation if I use /2 divider to get 22.xxM from 45.xxM XO.
Same idea 🙂.
http://www.diyaudio.com/forums/digi...mate-weapon-fight-jitter-346.html#post4162147
Merry Christmas
Ian
Same idea 🙂.
Merry Christmas
Ian
Thanks to Ian's support, now is enough clear how to connect TWTMC boards to Ian's Dual XO clock board.
You need two XO adapters, two u.fl connectors and a little tweaking to solder them.
Then, you can refer to the image I posted.
It could be very interresting for the Ian's stuffs owners to test the Andrea Clock with the 90.x Mhz Laptech crystals as Ian advises pper frequecies with its new clockboard design as well (90 Mhz) !
Happy Happy Merry Christmas to all diyers and the people they love... leave you, I have to coock real food now 🙂
Im thinking about doing something like this for Ian's dual XO board:![]()
This is not optimal to connect a good XO in this way?,the ground is not active?
The best would be to make a PCB with connection SMA.
"Also Andrea will there be any performance degradation if I use /2 divider to get 22.xxM from 45.xxM XO."
How would you respond to that Andrea.🙂
Good question. Difficult to say.
Usually the lower the frequency, the lower the phase noise.
In this case we have 22/24 MHz fundamental and 45/49 MHz 3rd overtone.
3rd overtone crystal, typically, has higher Q, that theoretically means lower phase noise. Also, dividing by 2, phase noise decreases, but the active device used to divide, introduces itself some jitter.
I believe we are in the mid-stream.
If I could use both indifferently, and I had a gun pointed at my head, probably I would choose 22/24 Mhz. But I have no specific reasons to support the choice.
Would be curious testing both frequencies with Ian's FIFO, and listen to the result.
Merry Christmas.
- kf_tam : 2x PCB
- JethroTull 1x 11.2896 Mhz + 2 PCB (with components, soldered o insoldered, it possible)
- kf_tam : 2x PCB
Merry Christmas
The ground is connected.
The top pin is connected to output and the lower one is to ground.
- kf_tam : 2x PCB
- Clsidxxl: 1 x 22.5792 MHz + 1 x 24.576 MHz+daughter board + 2 x PCB -With Assembly Service
- kf_tam : 2x PCB
TWTMC-DIL adapter board
Since there are many members who want use this clock with Ian's Dual clock board, I have designed a little board that fits directly to DIL socket.
The board provides three type of connector that could be used to connect XO board:
- 1 x u.fl connector
- 1 x SMA connector
- 2 x pin strip connector (to adapt left and right DIL socket on Ian's board)
Using pin strip connector, XO board could be soldered directly to the adapter board, avoiding any cable.
With this option, Xo's power supply (+15V, +5V/+3V3) should be wired to the daughter board, using a suitable wire triplette for each XO (+15V, +5V/+3V3, GND).
Board size is 0.7" * 0.55", 1.6 mm thickness, 2oz copper, ENIG finish.
If there will be enough interest, this adapter board could be supplied.
The cost for a quantity of 100 pcs is around EUR 2.00 each board.
For 50 pcs the cost increases to EUR 3.50 each board.
If anyone was interested, please add this option to the list.
- 1 x SMA connector
Nice!
Hmm, is this physically possible for 2 clocks on a Ian clock board. Could you in any way portrait this?
Hi Andrea,
I don't know if people need or one not two uf-l MCLK output connectors to feed such conf like a Fifo (or any slaved external streamer device) + a Ian I2StoPCM extra board which needs to be slaved by a MCLK uf-l embeded plug ?
Maybe experienced people with Ian's devices could answer this ?
At least does the main or daughter board provide more than one standalone uf-l connectors to allow multiple slavering ? Or does I miss something in the concept about clocking and slaving DAC devices ?
Sorry if OT or already answered!
Nice!
I'm not sure I understand your question.
For 2 clocks on Ian's dual clock board, you can simply use 2 adapters (one for each DIL socket on Ian's board).
Using u.fl or SMA connector there is no problem about physical space.
If you would use pin strip to solder directly each XO to adapter board, it provides a pair of connector: J6 should be used for the left DIL socket (U1), while J5 will be used for right DIL socket (U2) on Ian's board.
See attached image.
Hi Andrea,
Eldam,
Xo board provides 4 output connectors: 2 x u.fl, 1 x SMA, 1 x pin strip.
Daughter board provides 3 master clock output connectors: 2 x u.fl/SMA, 1 x pin strip.
To slave other devices at the same frequency, you can use all the above connectors.
If some devices need different frequency, you could use the dividers provided by the daughter board (again 3 connectors as for the master clock).
- andrea_mori : 5 x 5.6448MHz + 2 x 11.2896MHz + 3 X 22.5792 MHz + 3 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 90.3168 MHz + 1 x 98.304 MHz + 10 x PCB + 4 x daughter board PCB + 8 x adapter board
- kf_tam : 2x PCB
Updated for adding adapters.
- kf_tam : 2x PCB
Thanks Andrea.
OT: I Subscribed to your link about the soldering iron ! WS8 serie is too expensive for me but the one you showed is good (my chinese cheap soldering station collapsed few days ago) !
- kf_tam : 2x PCB
- palmito : 1 x 45.1584 MHz + 1 x 49.152 MHz; 1 x 22.5792MHz 1 x 24.5760MHz; 2 x PCBs; 2 x daughter boards; 4 x adapter boards
Updated, added adapters boards.
- kf_tam : 2x PCB
- Digital Line Level
- The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
