Thank you Andrea for the inputs:
so the crystal Fs choice depends on the needs of the slaved source if we want avoiding a diviser chip for the MCLK and BCLK mostly ? So that's why I choosed for the other crystals the 22/24 M hz family: because the futur streamer : certainly for me an Amareno as few device on the market can be slaved ! But for our old TDA here the input will be accepted in a x4 oversampled mode (5.6 x 4 = 22.xx).
So, it stays to me to understand if a material upsampled in a computer with a software (and I don't understand if the embeded clock of the computer is involved by this process in relation to its quality?) then played at NOS fhz (5.9 M hz) is better than a oversampled hardware mode with higher crystal Fhz which is at the end divided by a device (74xxx chip) before the dac chip if we want to stay in NOS mode or accepted as it is without division because the oversampling acceptance of the dac chip!
The weak link here seems to be the computer upsampling because the internal (bad) clock reference of the computer. And I bet at least the bad phase noise and noisy PS are not keeped in the computer upsampled file but does the precision of the pc clock is good enough for a software upsampling for our Red book materials ????
PS: I would be happy to see how a standalone 11.2 M hz Laptech is working in a old Philips DAC with some caps replacement as well 🙂 We could be very surprised perhaps !
Just insert the 11.2Mhz into the SAA7220 which usually comes with the TDA1541... 😎PS: I would be happy to see how a standalone 11.2 M hz Laptech is working in a old Philips DAC with some caps replacement as well 🙂 We could be very surprised perhaps !
Hurk ! Totaly forgott than the SAA7220 is art piece of enginering when it comes to create jitter 😉
I have a Marantz TDA1540s board somewhere... will try with it 🙂. A two cents : is a jittered good phase noise sounds better than a jitter maid by a bad crystal... ahahahha !
Correct 😉Hurk ! Totaly forgott than the SAA7220 is art piece of enginering when it comes to create jitter 😉
Yes, from my expert status I can confirm that a maid (any maid) produces more jitter than a crystal... 😀A two cents : is a jittered good phase noise sounds better than a jitter maid by a bad crystal... ahahahha !
Crystals and PCBs - finalizing orders
Since all the quote are available, I believe it's the time to close the waiting list, to finalize the orders.
The waiting list will be closed within December, 31.
PCBs:
TWTMC-C (clock board) Unit price € 2.00
TWTMC-C (daughter board) Unit price € 9.00
Laptech crystals:
11.2896 MHz
22.5792 Mhz
24.5760 MHz
45.1584 MHz
49.1520 MHz
We have reached the MOQ, so the unit price is € 27.00
6.1440 MHz comes out of the list, due to MOQ (100 pcs)
5.6448 MHz
we have to reach MOQ (15 pcs). If MOQ will be reached, unit price is € 29.00 (I will add 3 more pcs)
25.0000 MHz
16.9344 MHz (*)
we have to reach MOQ (10 pcs). If MOQ will be reached, unit price is € 27.00
(*) In case someone would get 33.8688 MHz 3rd overtone in place of 16.9344 MHz fundamental, to use with the divider, I have 5 pcs to sell, unit price is € 27.00
All prices don't include:
Paypal fees: 5% of the total amount
Shipping in an envelope: worldwide € 7.50, tracking within EU € 3.50 (no insurance included).
Combined shipping to Phil in a box (assembly service): € 2.00
Since I have to pay Laptech in advance, as soon as they send me the proforma invoice, next days I will begin to collect money via Paypal. I'll let know the total amount for each member.
Please, update the list where needed
Members who require assembly service, please indicate it in the list
Please, pay attention to desired crystal frequency and its MOQ. If the MOQ will not be reached for some frequency, that frequency will be removed from the list.
Andrea
Maybe I've missed this information elsewhere in the thread but how does things progress from here? Should I transfer money to you for the crystals I'd like to buy, or ...?
Jesper
PCBs:
Laptech crystals:
11.2896 MHz
22.5792 Mhz
24.5760 MHz
45.1584 MHz
49.1520 MHz
5.6448 MHz
25.0000 MHz
16.9344 MHz (*)
Andrea
OK, so for the Phil/Corben assembly case we will sort everything via him or order to you ourselves?''
- andrea_mori : 2 x 5.6448MHz + 2 x 11.2896MHz + 2 X 22.5792 MHz + 2 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 90.3168 MHz + 1 x 98.304 MHz + 10 x PCB + 4 x daughter board PCB
- Eldam : 1 x 5.6448MHz + 1 X 22.5792 MHz + 1 x 24.576 MH + 2 x daughter board PCB + 4 x PCB
- esgigt : 1 x 11.2896 Mhz + 1 x PCB, soldered if possible
- fralippo : 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughter board PCB
- mravinsky : 2 x 11.2896 Mhz + 2 x XO PCB + 1 x Daughter board PCB
- TNT : 1x22.5792MHz 1x24.5760MHz 1 x 49.152 MHz + 3 x PCB, + 2 x daughter board, all soldered if possible
- 1audio : 2x22.5792MHz 2x24.5760MHz + 2 x PCB + daughter board.
- randytsuch : 2x25.0000MHz + 4 x PCB + 1 x daughterboard
- myint67 : 1x11.2896mhz ,1x22.5792,1x45.1584,1x49.152 ,4 PCB ,2xdaughter board , soldered if possible
- kf_tam : 2x PCB
- BDL : 1 x 11.2896 MHz + 4 x PCB + 1 x daughter board PCB
- thorstenlarsen : 2 x 11.2896 MHz + 2 x PCB
- Zoran : 1x22.5792MHz 1x24.5760MHz + 2 x PCB, (soldered or not...) + 1 x 11.2896 MHz + 1 x PCB
- walangalam : 1 x 11.2896 Mhz + 2 x PCB
- AR2: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB (soldering not needed)
- mcluxun: 1 x 22.5792 MHz and 1 x 24.576 MHz 1 x 45.1584 MHz + 1 x 49.152 MHz+ 2 x PCB + 1 x daughterboard (soldering if possible)
- damohpi: 1 x 11.2896 + 1x PCB unsoldered
- noizas : 2 x 5.6448MHz + 2 x 11.2896MHz + 4 x PCB
- badrisuper : : 1 x 11.2896 Mhz + 2 x PCB
- Clsidxxl: 1 x 45.1584 MHz + 1 x 49.152 MHz+daughter board + 2 x PCB -With Assembly Service
- zeta4 1x 22.5792Mhz + 1 x PCB (soldering not needed)
- chertk : 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughter board
- hirez69: 1 x 22.5792 MHz and 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 4 x PCB (soldered) + 1 x daughter board
- palmito : 1 x 22.5792MHz 1 x 24.5760MHz + 1 x PCB + daughter board.
- gentlevoice: 1 x 6.144 MHz (see earlier PM) + 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz
- naimster: 1x 22.5792 MHz + 1x 24.576 MHz + 2x PCB + 1x daughterboard (soldered if possible)
- zenelectro : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB's + 1 x daughterboard (soldered if possible)
- Ryssen : 1 x 24.576 MHz + 1 x PCB soldered
- flowerpot : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- deanoUK : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- Miklos: 1 x 11.2896MHz + 2 x PCB + 1 x 16.9344 MHz
- Kannan_s:1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- Acko : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- tuyen : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB's + 1 x daughterboard (soldered if possible)
- Malvin : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- Marlowe: 3 x 16.9344Mhz + 3 x 25MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 22.5792 MHz + 1 x 24.576 MHz + 8 x PCB + 3 x daughter board PCB
- ppap64: 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board(soldered if possible)
- Superdad: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughter board (soldered if possible)
- ChrisMmm: 2 x 24.576 and 2 x PCB
- vita:1 x 24.576Mhz + 6 PCB
Thank Andrea for your Work,nice project.And Phil and Korben for your help.
What is the best way to connect your board (double clock) at the double XO of Ian,with a adapter,solder,SMA-UFL?.
- kf_tam : 2x PCB
- kf_tam : 2x PCB
- mcluxun: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughterboard (soldering if possible)
Thanks for the awesome project Andrea.
- kf_tam : 2x PCB
Combined way, crystals/PCBs from me and assembly/components from Phil.
I will ship crystals and PCBs to Phil, he will assemble the boards and finally he will ship the finished and tested boards directly to each user.
I'm waiting for Ian's reply in his thread
http://www.diyaudio.com/forums/digi...project-ultimate-weapon-fight-jitter-346.html
It's not clear for me what kind of connections are provided by his XO adapter.
I believe you could use short u.fl. cables.
- andrea_mori : 5 x 5.6448MHz + 2 x 11.2896MHz + 2 X 22.5792 MHz + 2 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 90.3168 MHz + 1 x 98.304 MHz + 10 x PCB + 4 x daughter board PCB
- kf_tam : 2x PCB
- kf_tam : 2x PCB
I think this will be u.fl cables as I'm looking at a mk II board right now and see u.fl inputs 🙂
Unfortunately I have not succeeded to establish communication despite a message to Phil so I can't really finalize my order before I get some reply and quotes.
Sorry, having to remove myself from the list.:
- kf_tam : 2x PCB
- kf_tam : 2x PCB
- kf_tam : 2x PCB
- bkdog 1 x 90.3168 MHz + 1 x 98.304 MHz + 2 x PCB + 2 x daughter board (soldered if poss)
- kf_tam : 2x PCB
As far as I know, Phil is working to define the cost of the assembly service, including components.
I think next days he will publish all the information.
Anyway, I have just sent him an email to know when he will be ready.
Hi All
Sorry for my late input, been busy dealing with DAC GB.
I've define the Assembly Service costs.
I'll try to do the same for the parts order form.
To avoid mistakes due to various configurations, I've to quote a "common BOM" and then add required parts for each request.
Link to the Assembly Service form :
https://docs.google.com/forms/d/1odqObA4PFXhxqxyqrZiAPSWgGCTsZBO19erk2LmXXHk/edit#
Prices for D&D board Assembly Service are subject to be reduced.
It depends on your final choices.
Consider the price mentionned in the form as the highest for a fully stuffed board.
A scalable cost will be provided according to your final configuration.
Note : For technical choices/questions ask Andrea and refer to this thread content.
Phil
Phil
Thank you Andrea for your help 😎
I've got your mail and usefull explanations.
Potato has drop me a mail.
Phil
Phil
Sorry, here's the correct link :
https://docs.google.com/forms/d/1odqObA4PFXhxqxyqrZiAPSWgGCTsZBO19erk2LmXXHk/viewform?usp=send_form
Phil
Phil
OK, I have to revoke this statement. There are indeed u.fl connectors but not for this function. Sorry!
- Digital Line Level
- The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
