The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
andrea_mori : 2 x 5.6448MHz + 2 x 11.2896MHz + 2 X 22.5792 MHz + 2 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 10 x PCB + 4 x daughter board PCB
- Eldam : 1 x 5.6448MHz + 1 X 22.5792 MHz + 1 x 24.576 MH + 2 x daughter board PCB + 4 x PCB
- esgigt : 1 x 11.2896 Mhz + 1 x PCB, soldered if possible
- fralippo : 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughter board PCB
- mravinsky : 2 x 11.2896 Mhz + 2 x XO PCB + 1 x Daughter board PCB
- TNT : 1x22.5792MHz 1x24.5760MHz 1 x 49.152 MHz + 3 x PCB, + 2 x daughter board, all soldered if possible
- 1audio : 2x22.5792MHz 2x24.5760MHz + 2 x PCB + daughter board.
- randytsuch : 2x25.0000MHz + 4 x PCB
- myint67 : 1x11.2896mhz ,1x22.5792+ 2pcb ,1 xdaughter board , soldered if possible
- kf_tam : 2x PCB
- BDL : 1 x 11.2896 MHz + 2 x PCB + 1 x daughter board PCB
- thorstenlarsen : 2 x 11.2896 MHz + 2 x PCB
- Zoran : 1x22.5792MHz 1x24.5760MHz + 2 x PCB, (soldered or not...)
- walangalam : 1 x 11.2896 Mhz + 2 x PCB
- AR2: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB (soldering not needed)
- mcluxun: 1 x 22.5792 MHz and 1 x 24.576 MHz 1 x 45.1584 MHz + 1 x 49.152 MHz+ 2 x PCB + 1 x daughterboard (soldering if possible)
- damohpi: 1 x 11.2896 + 1x PCB unsoldered
- noizas : 2 x 5.6448MHz + 2 x 11.2896MHz + 4 x PCB
- badrisuper : : 1 x 11.2896 Mhz + 2 x PCB
- Clsidxxl: 1 x 45.1584 MHz + 1 x 49.152 MHz+daughter board + 2 x PCB (soldering if possible)
- zeta4 1x 22.5792Mhz + 1 x PCB (soldering not needed)
- chertk : 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughter board
- hirez69: 1 x 22.5792 MHz and 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 4 x PCB (soldered) + 1 x daughter board
- palmito : 1 x 22.5792MHz 1 x 24.5760MHz + 1 x PCB + daughter board.
- gentlevoice: 1 x 6.144 MHz (see earlier PM) + 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz
- naimster: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB (soldering if possible)
- zenelectro : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB's + 1 x daughterboard (soldered if possible)
- Ryssen : 1 x 24.576 MHz + 1 x PCB soldered
- flowerpot : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- jcastellano: 1 x 11.2896 Mhz + 1 x PCB, soldered if possible
- deanoUK : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- Miklos: 1 x 11.2896MHz + 2 x PCB
- Kannan_s:1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- Acko : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- tuyen : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB's + 1 x daughterboard (soldered if possible)
- Malvin : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- myint67 : 1x11.2896mhz ,1x22.5792,1x45.1584,1x49.152 ,4 PCB ,2xdaughter board , soldered if possible
- kf_tam : 2x PCB
- kf_tam : 2x PCB
- kf_tam : 2x PCB
- Marlowe: 2 x 16.9344Mhz + 2 x 25MHz + 2 x PCB + 2 x daughter board PCB
- kf_tam : 2x PCB
- naimster: 1x 22.5792 MHz + 1x 24.576 MHz + 2x PCB + 1x daughterboard (soldered if possible)
- kf_tam : 2x PCB
- Marlowe: 3 x 16.9344Mhz + 3 x 25MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 22.5792 MHz + 1 x 24.576 MHz + 8 x PCB + 3 x daughter board PCB
@TNT
As I said in post #1 I'll go to university lab to measure when all the 3 oscillators will be ready (Clapp, Butler and Driscoll).
At this moment I'll build some XO, fundamental and 3rd overtone, to test they work correctly. Every crystal will be provided with its specs, ESR, motional capacitance, Q (Laptech provides these specs for each crystal).
Furthermore I'll build a daughter board to test it works as designed.
@kf_tam
There is new request for 16.9344 MHz crystals, if you are still interested on such frequency, we can reach the minimum orderable quantity.
@Eldam, @DC
Surely mica caps are the best for the tank circuit. I would use mica or C0G/NP0 X7R.
Mouser offers SMD mica caps from Cornell Dubilier, some are 0805 other 1210 package. The XO board provides footprint for 0805 caps, but it not should be a problem to accommodate 1210 caps.
- kf_tam : 2x PCB
-ppap64: 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board(soldered if possible)
@TNT
Great stuff!! 🙂
ETA?
- andrea_mori : 2 x 5.6448MHz + 2 x 11.2896MHz + 2 X 22.5792 MHz + 2 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 10 x PCB + 4 x daughter board PCB
- kf_tam : 2x PCB
- BDL : 1 x 11.2896 MHz + 4 x PCB + 1 x daughter board PCB
- ppap64: 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board(soldered if possible)
- kf_tam : 2x PCB
- Superdad: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughter board (soldered if possible)
- kf_tam : 2x PCB
- Zoran : 1x22.5792MHz 1x24.5760MHz + 2 x PCB, (soldered or not...) + 1 x 11.2896 MHz + 1 x PCB
- kf_tam : 2x PCB
- Miklos: 1 x 11.2896MHz + 2 x PCB + 1 x 16.9344 MHz
- randytsuch : 2x25.0000MHz + 4 x PCB + 1 x daughterboard
- kf_tam : 2x PCB
Updated my order
- kf_tam : 2x PCB
- ChrisMmm: 2 x 24.576 and 2 x PCB
I didn't see any mention of duty cycle, but some converters are very sensitive to it and need 50/50. This is a good reason to do a double-speed clock and divide it by two. It is particularly important if you clock distribution scheme has any asymmetry in rising vs. falling edge speeds, which will degrade the duty cycle.
Also, I see the design uses a resistor divider to generate the DC slicing threshold voltage that is coupled to the first inverter. A neat trick is to instead use a spare inverter and short its input directly to its output. It will then "find" its own ideal slicing threshold, which you can then couple to the front end inverter. For this trick, it is usually good to use a xxU04 and use an inverter in the same package as the slicer to get good matching. If you couple this threshold voltage to the input inverter using a pulse transformer, you have a very nice bulletproof S/PDIF receiver.
DC
Just tested, duty cycle is exactly 50%. Thanks for the suggestion.
I've updated schematic and PCB adding this option. I have also left the resistor divider, so one can choose between the two slicer options.
Until now I haven't encountered any crystal starting at wrong harmonic, so I would avoid to make more complex the PCB including a varicap diode plus a trimmer to set its voltage. Anyway, in case of a crystal starting at wrong harmonic, one can put a capacitor trimmer in place of C8 to tune the crystal.
  • TWTMC-C.pdf
    TWTMC-C.pdf
  • TWTMC-C_Part_List.pdf
Mounting service
Since Phil gave his availability to offer the mounting service, all members who are requesting this service have to specify their own customization of each board.
We could do the following:
- each member send a PM to Phil, indicating the desired customization
- Phil will quote the mounting service (including all components except for crystals and PCBs)
- I will ship all needed crystals and PCBs to Phil
- Phil will build and test each board, and finally he ship the finished boards to the final destination
You have to specify the following:
for each TWTMC-C (XO)
- desired frequency (to choose the right components, fundamental or 3rd overtone)
- slicer option: first or second (see schematic)
- output voltage: 5V or 3V3
- logic option (3V3 only): standard LVCU or Potato Semi logic
- outputs option: J1 (u.fl.), J2 (u.fl.), J5 (pin strip). To use in conjunction with daughter board, pin strip is needed.
for each TWTMC-D&D (daughter board)
- dual XO option: yes or no (if yes, relay K1 and all logic to drive it are needed)
- XO selection option (dual XO only): pulse or Low/High
- power off oscillator not used (dual XO only): yes or no (if yes relay K2 is needed)
- dividers options: no or /2, /4, /8, /16 (3 maximum, due to limit in output connector)
- dividers output connector (dividers only): J11 (u.fl.), J12 (u.fl), J10 (pin strip), J19 (SMA), J20 (SMA). Max 3 of these.
- master clock output: yes or no
- master clock output connector: J13 (u.fl.), J14 (u.fl), J7 (pin strip), J21 (SMA), J22 (SMA). Max 3 of these, alternative to delayed clock.
- delayed clock output: no or 1, 2, 3 (see PCB image)
- delayed clock output connector: J13 (u.fl.), J14 (u.fl), J7 (pin strip), J21 (SMA), J22 (SMA). Max 3 of these, alternative to master clock.
- output voltage (dividers and/or delayed clock only): 5V or 3V3
- logic option (dividers and/or delayed clock, 3V3 only, ): standard LVCU or Potato Semi logic
- rectification and filtering on board: yes or no
- regulators on board: yes or no
Please, send PM to Phil with your desired customization.
Tomorrow I wiil ask Laptech for the crystals quotation.
