The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
- andrea_mori : 2 x 5.6448MHz + 2 x 11.2896MHz + 1 X 22.5792 MHz + 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 10 x PCB + 4 x daughter board PCB
- Eldam : 1 x 11.2896 Mhz + 4 x PCB
- esgigt : 1 x 11.2896 Mhz + 1 x PCB, soldered if possible
- fralippo : 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughter board PCB
- mravinsky : 2 x 11.2896 Mhz + 1 x PCB
- TNT : 1x22.5792MHz 1x24.5760MHz + 2 x PCB, soldered if possible
- 1audio : 2x22.5792MHz 2x24.5760MHz + 2 x PCB + daughter board.
- randytsuch : 2x25.0000MHz + 4 x PCB
- TNT or maybe : 1 x 11.2896 Mhz + 1 x PCB, soldered if possible
- myint67 : 1x11.2896mhz ,1x22.5792+ 2pcb ,1 xdaughter board , soldered if possible
- EdwardTam : 2x 16.9344MHz + 1 x 11.2896 Mhz + 2x PCB
- BDL : 1 x 11.2896 MHz + 2 x PCB + 1 x daughter board PCB
- thorstenlarsen : 2 x 11.2896 MHz + 2 x PCB
- Zoran : 1x22.5792MHz 1x24.5760MHz + 2 x PCB, (soldered or not...)
- walangalam : 1 x 11.2896 Mhz + 2 x PCB
- AR2: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB (soldering not needed)
- mcluxun: 1 x 22.5792 MHz and 1 x 24.576 MHz 1 x 45.1584 MHz + 1 x 49.152 MHz+ 2 x PCB + 1 x daughterboard (soldering if possible)
- damohpi: 1 x 11.2896 + 1x PCB unsoldered
- noizas : 2 x 5.6448MHz + 2 x 11.2896MHz + 4 x PCB
- badrisuper : : 1 x 11.2896 Mhz + 2 x PCB
- Clsidxxl: 1 x 45.1584 MHz + 1 x 49.152 MHz+daughter board + 2 x PCB (soldering if possible)
- zeta4 1x 22.5792Mhz + 1 x PCB (soldering not needed)
- chertk : 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughter board
- hirez69: 1 x 22.5792 MHz and 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 4 x PCB (soldered) + 1 x daughter board[/QUOTE]
- palmito : 1 x 22.5792MHz 1 x 24.5760MHz + 1 x PCB + daughter board.
- gentlevoice: 1 x 49.152 1 x 6.144 MHz 1 x 24.576 MHz + 1 x PCB
- naimster: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB (soldering if possible)
- zenelectro : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB's + 1 x daughterboard (soldered if possible)
- Ryssen : 1 x 24.576 MHz + 1 x PCB soldered
- flowerpot : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- zeta4 1x 22.5792Mhz + 2 x PCB (soldering not needed)
- flowerpot : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB[/QUOTE]
Update for 2 x pcbs
-jcastellano: 1 x 11.2896 Mhz + 1 x PCB, soldered if possible
- EdwardTam : 2x 16.9344MHz + 2x PCB
Joined 2007
- gentlevoice: 1 x 6.144 MHz + 1 x 24.576 MHz + 1 x 49.152 MHz
TNT
Joined 2003
- TNT : 1x22.5792MHz 1x24.5760MHz + 2 x PCB, + 1 x daughter board, all soldered if possible
- jcastellano: 1 x 11.2896 Mhz + 1 x PCB, soldered if possible
- deanoUK : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- myint67 : 1x11.2896mhz ,1x45.1584,1x49.152, 3pcb ,1 xdaughter board , soldered if possible
Miklos: 1 x 11.2896MHz + 2 x PCB
Would it be possible to use the daughter board for the power feeding convenience but still extract (simultaneously?) the individual clocks via u.fl?
Yes, you can fit two XOs on the daughter board to share the power supply and then take out the signal of each XO via u.fl.connector directly from the oscillator boards.
The daughter board will accommodate only rectification, filtering and regulators; you don't need to connect the two XOs with the daughter board via pin strip.
items update for Eldam
- Eldam : 1 X 22.5792 MHz + 1 x 24.576 MH + 2 x daughter board + 4 x PCB
- Miklos: 1 x 11.2896MHz + 2 x PCB
- Kannan_s:1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- andrea_mori : 2 x 5.6448MHz + 2 x 11.2896MHz + 2 X 22.5792 MHz + 2 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 10 x PCB + 4 x daughter board PCB
Closing the list
I think it's the time to close the list and ask Laptech for the crystals quotation.
@TNT
You are two times in the list, please let us know the final choice
@EdwardTam
You are the one requesting 16.9344 MHz crystal, I own some 33.8688 MHz crystals, so you could get two of them and then divide by 2 using daughter board, please let us know
All other frequencies for quantity below 5 pcs
I ask anyway Laptech for the quotation, but I'm not sure they will produce such quantity
At this moment there are requests for 74 x XO PCBs and 20 x daughter board PCBs.
I will order 100 x XO PCBs and 30 x daughter board PCBs.
The final unit price cost for me, including VAT, fees, Paypal fees and so on are:
XO PCB:
Size 1.75" x 1"
Board thickness 1 mm
Copper weight 70 um (2oz)
Surface finish Ni/Au
Unit price € 2
Daughter board PCB:
Size 4.25" x 3.25"
Board thickness 1.2 mm
Unit price € 9
Please, revise your request if needed.
