The Very Best Amplifier I Have Ever Heard!!!!
The plan of the amplifier shows two resistors 15κ-10κ to give result 6Κ who in relation to the resistance value 330Ω give a gain value Χ 18,18 Resistance value 8,2K relation to the resistance value 330Ω give a gain value Χ 24,84 when i put 8,2k i get more wide square wave and the sound more clear/
Any advice please??
Have a look at my post #1776
hi there, well done.....it looks great.
Apologies for asking, but do you have a final parts list for the build? I only ask as I bought the boards sometime ago, then suddenly there was alot of do's and do'nts, should be this this way/ or the other, so sadly I lost interest. Today I have log-in after quite some time and spotted your finished Amps..they look great. Cheers, Nicholas
Hi Nicholas,
I hope that is all the information here:)
I'm on the board:
C3= 4,7PF
C5 = 10PF
C6 = 4,7PF
C7 = 4,7PF
T7 between B-C: 4,7PF
R20 = 330R (bias 100ma per transistor)
Transformers (TOROIDY.PL Transformatory Toroidalne Producent, Audio, Separacyjne, Trójfazowe, 230/110V, 110/230V, Na zamówienie) : 2x50V/500W (2 bridges for channel)
It is the same 2x50V /500mA for BD249/BD250
from the bottom PCB - 2x 10000/100V.
on PCB - 2x4700/100V.
Best regards.
  • PCB.2. Goldmund9.2.pdf
  • bom Goldmund 9.2.pdf
Hi vitalica,
There is a newer schematic, see blow
Somewhere between page 160-170, this new sch. surfaced. The thing I worried most is the T6 which has its CE 'reversed'. Worth discussion? I had a modified pcb laid for this new sch. too.
BP
  • GOLDMUND NEW SCHEMATIC PDF..pdf
I thought this one had been nailed a long time ago!
Both orientations result in a forward biased diode, so are equivlent.
The only difference, (not relevant here) is if the polarity is reversed; the top configuration sees a BE reverse zener of about 6.2V, the bottom one whatever VCBo is, which could be high.
Cliff,
what's wrong?
Your 896 by 896 pixel >100kB pic is perfectly visible/legible at the thumbnail resolution of 150 by 150 pixel and just 3.7kB
I do like your explanation of the difference in reverse orientation. 4 ways to connect and 4 different results.
I must be missing something?
Why is the resolution a problem for you? Are you still on dial-up 300baud? :D
"4 ways ..." Not sure what you are getting at! I was trying to show that if the PCB had the transistor inverted it makes no difference since it is used as a forward diode in the CCS tail. So ONE result, not 4.
I didn't say it was an issue.
I noted your comments and the fact you were drawing our attention to how the device operates with different orientation and different polarity.
I had not thought that through, as thoroughly, as you have.
Although I didn't use the words. I was in effect thanking you for pointing out the 4 variations rather than just leaving us ignorant of the implications.
Golmund clone
Box-transformer
χαλια ... χαλια ...χαλι μαυρο....
( that was cra**y work ... but in plain Greek )
Nick the metal work is a masterpiece and i expect it when painted to look marvelous only i wonder how much of this tank made box will add anything to the sound of your amplifier ....
Your case ( and others also ) should be a subject to the NVA amplifiers article which in a few words said that steel boxes are no good for audio amps , aluminum boxes sound terrible , so they ended up with a plastic box but without screws since screws effect the sound of amp for the worst
Read the article ...it might change your aspect of life ....
