The Singing Bush
Both supply’s are done and tested.
well , heat of NTCs itself , from experience - can't melt them ...... but NTC is having solid core leg , while these are having lousy screw connection ( even if some having intermediate metal tab between screw and wire) , where you have potentially bad contact, and you know that results in heating with time
it is really optimized/made for strand wire , not for any sort of solid core , which is simply giving up of pressure in time
Ahh..I see
How bout crimping? Also what do you do so it won't loosen with time? I had bad experience so just solder them after crimping. Depending how it looks
. I like wago.now. Use spring loaded clips similar like pheonix contact. Reliable.
