The Singing Bush
to jjasniew
As I know: the multiple JFets in phonostages are used to lower noise and to
increase amplification - especially in MC-stages.
I think Zen Mod is using 3 Toshiba 2SK2145 paralleled to increase the transconductance of the devices instead of using one Toshiba 2SK170.
And I think they sound really good?
But it is better to ask Zen Mod himself. It is his design!
Greets
Dirk
oh yeah
Mum , see ....... I invented The Wheel!!
You gonna see me on The Telly!!
:rofl:
JFets in parallel are functioning same as well trained Horses , drawing Carriage; together they're making lesser rumble , while being able to pull much more and more abrupt than sole one
in this case , I'm using 3 double ones in parallel , to be same as Brave Tailor Mickey , and to have greater Iq , lesser Rout, while still sane dissipation per each tiny bugger
nicely low and shaped THD is pure bonus and beginners luck
:clown:
aha!
my Petri Dish did bring whatever she's bringing home from School every Winter .... I felt so sleepy last few (or even more than few) days , knowing that some Virosis is there ...... anyway - yesterday I did plan several things , first o them being test of MosPuck gain pcb in Schaded Singing Bush
after lunch I came to idea of wasting 1L of Uberstrong Tea, with EEEEeeeverything in it (too much things to even start mentioning) and I did ...... after finishing second cup I fell to sleep :rofl:
dunno , I did woke up several times after that (that's Tesla Spirit in me) but I can't clearly remember ; it seems I posted something at least few times, but I cant't clearly remember that also
in a meantime , I know I dreamt at least one original movie , at least one line level stage and at least one speaker construction
bummer is that I'm remembering just the movie 😛
so , Schade definitely today
The Singing Bush Schade ......
Ok , that's it
Early morning coffee , then up to Workshop , another coffee in da coffee-maker
lazy finishing assembly of Schade pcb on heatsink , some wiring re-work ad that's it
funny behavior - RC constants are sooo big , it biases after few minutes ; output node voltage rises fast to full rail , simply because both mosfets aren't conducting ..... then it goes down softly and slow
besides - output node voltage stabilizes really at temp. equilibrium , and then everything is rock stable
The Singing Bush Schade, 8R Load
Rail 60Vdc
Output node at 28Vdc
Iq 3A2
gain for 5Vrms out
8R load, 514mVrms in ; A=9.72V/V = 19.76db
The Singing Bush Schade, 4R Load
Rail 60Vdc
Iq 3A2
gain for 5Vrms out
4R load, 554mVrms in ; A=9.19V/V = 19.26db
Zenmod, how does this differ from SissySit, in dumbed down layman's terms....I do have extra set of TH51....
But waiting to get final version to finish SissySit.
Or, should I make that one M25 and proceed with Burning Bush....assuming boards will be available.
Or, wait until new SissySit boards are available with latest changes?
Russellc
to Zen Mod #64
My 50W - SE- Schade - amp behaves exactly like yours.
It needs a long time to turn on and to warm up but then it is rock stable.
Only my node voltage at speaker output is much higher. But I am still testing / adjusting. 🙄
Greets
Dirk
Russellc
First ....... SissySIT is one heluva nice amp , special in character ( blame Papa, as always) ..... having measured 18W per channel , being wicked just enough and then little more;
what one can expect from pure SE , little higher in THD than usual , 50W SE amp made with SIT ? ........ think what's difference between nice and holographic 300B amp and cousin made with 845 , not sparing with iron and copper and caps ....... in other words - that's pure madness ...... completely other side of already borderline hobby
kits for Burning Bush will be available , but remember that main thing - all Lego Puzzles are long known and you can make it in whatever level of complexity you prefer .... even on Veroboard
so - is time for you to sin big , only you can tell and decide
me personally - I don't need that amount of power ....... and I would certainly skip that train if Papa didn't leave Workshop , making a situation for me to rummage through his most precious Shoe-boxes ...... so now I must make a pair of these Kudos amps :bawling:
new SissySIT boards will be available first moment when someone shows interest in them , but if you already have them , decision will you proceed with these - with original opto arrangement , or later tweaked ones , or you prefer new ones , that's up to you
Greets
Dirk
I opted for that value (28V at output node) counting on fact that Papa is always putting his AP1 to good use ...... for what one needs to have a brain
that's why I'm using EMU1212 and I don't have AP1 :clown:
there is slight possibility that Pa simply left that value from previous schematic - with 2SK77B , even if it not reflects real situation with mosfet pucks , and you always must count on possibility of some slight mistake in his schematic ..... but that's Nature of the Beast , his way of keeping Greedy Boyz on tips of their toes ....... and that's good thing - resulting sometimes in some gray cell engaging , not just blind copying what he drew
Schade version - very interesting and affordable 😀
yup, Bubba 🙂
yup, Bubba 🙂
I will wait until your mods to Sissy are done, if I think I can do it "gracefully" I will go that route. If not, will PM about new boards, and make this one M25. I have your M25 outputs, as originally that is version I bought.
All said, something whispers to me that I need the SissySit.....good sleep notwithstanding!
Thanks,
Russellc
The SissySit is very very nice - I think ZM is modest 😀
I will do a Singing Bush just because its an experiment and I wand to compare.
I did the Schaded M2 for the same reason - it will remain at the house as a back-up to the Sissy.
Best
Bob
I did explain in Babelfish M2-SEF amp thread how to Schade any M2 ...... matter of one additional resistor and re-setting DC Offset
I didn't tried Schade Babelfish M25 , that horse is for other course
regarding modesty , what Bubba Flocchini mentioned - it wasn't my intention to be modest ( nor is that my habit ) ...... I know how SissySIT is faring with DEFiSIT ( and SIT-3) , and I'm damn satisfied
:clown:
