The simplistic Salas low voltage shunt regulator
I'm using two 1,5V battery in parallel
If I were you I would have set the battery between the pot and ground instead (given that the devise feeding it has an output cap). The fewer batterys you serial the higher the tube bias current, which you best measure over 47K.
