That is the same schematic.... You are not using C2 (47uF EL) ?
Ooops sorry Ricardo yes I'm using Pana FC as per Salas advice.
i have a question.
i want to power the input stage of hypex ucd700hg with hxr regulators.
the performance of salas is better than the hxr regulators.
should i remove hxr`s or i can leave them in place?
what happens when we put the two regulators in series?
will the second add noise to the first?
SSLV is meant to feed the load directly. IMO there is no point in using a shunt to power another reg... Maybe you can use the hxr as preregs... maybe not.
TMN nobody tryed that before... please let us know about your experiments. 🙂
That is a pity.... I was starting to imagine what a V12R should sound without the output EL...
It is funny that I can clearly choose parts changes imagining the outcome before I do the mods.
For instance, in the RFKTR I got sparkling detail and transient behaviour by reducing output cap value.... After that, I subjectively lacked some presence in the upper bass, lower mids... After one thoghtfull night, I decided to increase the Vref MKP bypass (both in value and in size) so I went from a 3u3 400v mkp to a 4u7 600v mkp and the warmth became again.... without loosing any of the previous sparkle.
I can now imagine what it would be if I had a good 10u amphom or even better (obbligato), around.
This new design is so stable that is a delight for the "voicer", responding firmly and previsibly to any cap type/value choice.
Of course I will keep V12R in the top of my priority list because it is so extended and able to present a large and powerfull sounstage even with average quality components (once properly voiced together that is).
V12 is even more extended and able to recreate enourmous sounstages but very difficult to implement and highly dependent of the load... It can even pick up and amplify hum created by less than perfect gnd setups in the amp boards.
Anyway, I was never able to tune the V12 so it lacked some presence in my builds.
So IMO we have the following choices:
V1 - Super stable, good sounstage, almost perfect balance in terms of musicality versus detail. - A real singer.
Reflektor - Still in beta form, highly stable, fast voltage reaching, inexpensive easy build, can widstand the most outrageous mods responding with great predicability. needs some tunning to reach it´s best but rewards you with a very wide and deep sounstage due to it´s inherent large extension.
V12R - Super design, betters the previous ones in soundstage demonstration, bass and trebble extension and detail but needs very carefull execution. Can sound outstanding even with lesser parts but excels if built without compromises.
V12 - A special unfinished project (needing tunning) that produced the sweeter trebble and wider sounstage I ever heard from my riaa builds, but lacked the musicality of the V1.
You forgot the 1.1 Bib which is a fine solution for stability and building ease. For sonics it has good balance between those types you mentioned. You probably haven't used it yet.
I did not build it yet so I have no opinion, but due to it´s great flexibility, I would say it can have the musicality of the V1 but better because we can tune in so many ways.
hxr are mounted on the modules and can`t be used as pre regs.
and desoldering isn`t easy.
If you cascade regs you can enjoy some pre-reg enhancement. What is best should go last, but if you don't have a choice, see with a test if its worthwhile. Be careful of possible bad interactions, like the last putting into oscillation the one before, noise, etc.
thanks i will do the test.
Due to high voltage required I can't test BiB in Simplistic NJFET RIAA😡
I can do the test Vs V1.2R powering my BII, I will let you know subjective opinion.
Why not?
The BiB is designed to be very flexible. Both in output current and output voltage.
I need 45Vout for my Simplistic NJFET RIAA😡
Then get a 40Vac or 45Vac or 50Vac CT transformer.
or
Convert a 20+20Vac or 22+22Vac or 25+25Vac dual secondary to Centre Tapped.
or
I need also the same voltage +45Vout & -45Vout for my New Take on the Classic Pass Labs D1 with an ESS Dac????
I have two R-Core 120VA both with dual secondary 0-24V that I can converte in one 0-48VAC but that exceds 36ACv max input allowed writed by Salas in his BiB Rev.2?
http://www.selectronic.fr/catalog/product/view/id/17840/s/transformateur-r-core-120va-avec-etrier/category/172666500/
- Power Supplies
- The simplistic Salas low voltage shunt regulator
