The simplistic Salas low voltage shunt regulator
Changed R1 to 15R, now I have 1.85V across R1 (0.123A), 9.14V across Leds.
Rod I have other Tx 8.5V could be better?
Now parallel the 15r & 16r.
You should get just less than 0.116A + 0.123A ~ 0.23A
Now find the resistor required for the remaining ~70mA, somewhere between 27r and 39r.
BTW all of these resistors can be 500mW or 600mW size.
If you had 20r or 22r, then three of 600mW would be almost perfect.
Have you read WJ yet?
Have a look at Walt Jung's papers describing simple and more complicated current regulators. The simplest uses just 2 components, a resistor and an LM317.
you can try to do this circuit, Get current it is easy, only use trimer 500R
Please ignore the Quanghao drawing, unless you want to change to a much lower power supply, and use this totally different circuit!
If you have a 17-18V supply, 9,2V across the LEDs, you should be OK. Just check for 5V across R1, then change the value of R1 until you get 0,29 to 0,30A
What is Ok, Quang Hao schematic?
Quanhao schematic is NOT OK. There is likely to be stability problems, if you build the circuit like that.
I notice that Quanghao is attempting to sell filament regulators on his site, using design elements copied from my DIY kit filament regulators (he bought one last month to get a closer look). I should make it clear that, although he is using my description "Gyrator + CCS" filament regulator, this circuit is not designed by me, nor am I able to support it. AND, If the snapshot above is used in the regulator, there is VERY likely to be trouble from oscillation, and other effects as well.
The parts of the design taken from my kits were used without the politeness of asking if it was OK.
I am sorry to read that.😡
