hey bill, are you sure there is no DC across the pot? ...but its not unusual to get a crackling sound when you turn the pot if there is either DC present in the signal, or if one of the caps in the signal path is installed with reversed polarity
There is a film output cap at the CD player so there should be no DC and no reversed polarity.
Hi Bill,
Cardas, DeoxIT, etc & have metal contact cleaner if you want to try, If I was you I do a test looking the contacts searching the bad green oxide or dust, if it's dust you can remove with a computer air spray, if it's green oxide is the worst case you must remove sanding the contacts with a lot of care.
Cheers
Felipe
This may be it. The attenuator is not enclosed so dusts can always get into it. What makes it worse is that my preamp has no top cover at the moment because the shunt regs with internal heatsinks run fairly hot so I can't put the top on. I need a new power amp chassis to redo my line level crossover, something I am planning to do in the near future.
As for contact cleaner, I have seen a few types and am not sure which one to get. Some claims to remove dusts only. Do others remove any oxidized metal layer as well? or is it necessary?
Hello Salas,
Which version is best for 5V Output Voltage?
And how much current it can provide?
Up to the amperes that the Mosfets can safely take on each given sink and dissipation relation created by the voltage and current targets.
V1.0 I would prefer. Gives most margin. The 1.2&1.2R are compound output pair, and their open loop standards will slide in the xAmp region and would need tests for compensation tweaking. Prefer a faster TO-220 for Q1 like 9610-9620 if for digital.
Thanks about the update on the cheapo pot Bill. It was in DCB1 threads there was interest. True its no mechanical wonder and its open. Could survive more if not exposed to dust though, or skip it a bit longer with the odd cleaning service. Not bad transparency for $10 though.
First look to see what's the problem, surely if you don't use cover have to be the dust so an air spray computer do the trick, if it's oxidized you know what do you do, about contact cleaner without deoxidization I prefer something don't left any kind of residue like the Audioquest UltraConnect 2 or CaiKleen 41 (Caig Labs) but if it's oxidized your product is only Caig DeoxIt you have to choose the specific product depending the amount of oxidation in the contacts.
If you can't cover use a plastic film like used to freeze to cover the stteped attenuator
Sorry for OT Salas
right nice OK, I was planning on using IRF9510/510 I have here already for my dac at some point, sounds like its a decent idea? the 510 models have higher dissipation and higher max drain current too.
sounds like dirt is the culprit then, hope you get it sorted soon. another vote for caig products here
As it is in post #3200 is OK.
It's for me your answer? post 3200 shows only IRF9240 for positive rail!!! about R13 0.22R it's ok Mills?
is it OK to use CREE C3D04060 zero REC Sic TO220 diodes in place of the MUR140? in V1? I only ask because I am buying some for another project and can get them reasonably cheap. they are 600v 4A schottkey
- Power Supplies
- The simplistic Salas low voltage shunt regulator
