The Kuartlotron - keantoken's simple error-correction superbuffer
The buffer can be trimmed for minuscule distortion.
The distortion cancelation can be even so high that i suppress 2nd harmonic in my analyser !
The best copy of the input signal is at 250 Ohm ( rather high, there was 1 56 Ohm before,
i only tested higher values but i will also try to lower the 56 Ohm ).
The best cancelation of the analyzer happens at 470 Ohm.
Sure, it´s odd and i will measure Vbe.
Installed now 270 Ohm in both channels and they measure very much the same.
Will listen tomorrow.
Could not find a trim with lower value.
Measured the TKD pot at -30dB and -70dB.
No distortion so this red herring is from the table.
From Kean's article :
Reduce output impedance
Output resistance at the emitter of Q4 may be negative or positive, and it's important to keep it from going negative or else you risk oscillation. For this reason I would recommend at least a 4.7R output resistor. The 47R output resistor was chosen for best compatibility with signal cables. Transmission lines are reactive by nature and without the right termination impedance, become a cascade of series and parallel resonators. Without termination, the cables become antennas for RFI. 22R-47R is a good range for damping cable resonances. Without termination, any buffer will resonate with the cable's series resonance mode; the 47R resistor was chosen to prevent this.
Kean,
Can you tell me what is the purpose of output resistor R10 (47 ohms)? Can it be of different value? I broke my 47ohm leads and hence am looking at my parts bin for alternative.
