The high octane phono preamp
atupi, thank you.
any idea what that three contact plug is called?
Use your imagination. Google 'TO92 socket'. See attached.
Jan
Yesterday i was playing with High Octane preamp and with another diy preamp but OPAMP based (Rod Elliot P06). After listening some songs with opamp preamp i moved to High Octane and observed the trebles are faded out and started playing with loading resistors. In P06 i use standard 47k loading resistors the same in high octane but it seems high octane have a different behaviour regarding loading. Can someone explain to me why is that ?
I use a MM Nagaoka MP110.
If sound difference persists you can consider first some difference in RIAA actual curves (eg. tolerances) between projects.
Meantime i have installed the 100k input resistor and sound is more balanced. I would really love to have the fullbodied bass from the P06 opamp phono preamp on high octane, as details and openess is nice on high octane but bass a bit shy and dry
My take on the High Octane
Finally found some time to take some Snaps (had to listen before 😀).
I used KSA1845, tried also BC550 but measured slightly higher noise (though still very low) and so the 1845 went in again. RIAA caps and resistors have been selected out of a dozen and final deviation is <0.5dB with channel mismatch smaller than 0.1dB.
PSU is a small DIY plug housing unregulated linear supply ~50V DC.
I like the sound, its very detailed and punchy 🙂 Very nice Project, thanks a lot to Hannes :cheers:
kind regards, Daniel
