Foobar... I know it supposed to be Bit perfect, unnecessary plugins out (I figured it out when I had some tik, tak noise and other junk coming from it) to load the processor, etc. I don't have external DAC, but isolated ground or fiber optic would be the way to go (damned Chicago downtown). I don't think that USB was designed for audio data transfer when it was introduced. I tried DSD files, but can not commend whether it sounds better - deafness and/or equipment not good enough up to the job. I'm a bit sceptical that I would hear improvement over regular but really very well recorded 96k, 88k PCM, even CDs and 48k - something along MA Recordings, etc. Maybe... Foobar converts DSDIFF, DSF to PCM, so I don't really see any advantage of 1 bit processing over PCM, in my computer set-up using Foobar.
Mark since your system is way better than my junk, any commends on your experience with DSD.
Tyler,
I will try the SOX plugin, if it works in my junk, and if it does whether it affects my deafness issue.
Anyone tried the Audiophile Linux?
Tyler, any chance you could do a talk about USB and DAC's? (or maybe we can just have a chat at some point at the meetup)
One thing I was wondering about in regards to the USB -> I2S thing from DIYINHK is what the linux kernel support was like. I had heard contradictory information on that, some saying it doesn't work, some saying you need a proprietary driver others saying there was kernel drivers.
Also, do you have schematics up anywhere for your stuff? I'd love to take a look at the PCB routing stuff.
I'd like to hear this talk too, if you're up to it Tyler
To be a naysayer, If you have a good recording on CD or SACD even identical ones. It is very difficult to distinguish between them.
I can tell some interesting little stories about playback at audio shows if you guys remind me.
I have run two demo rooms at two different Rocky Mountain Audio Festivals.
And did it with equipment that was valued well above six figures.
Had some interesting insights.
Okay I put my USB DAC in the presentations sheet. I can't speak too much to the USB side, but I know a bit. I've always just purchased USB->I2S converters as most of the ICs involved can't be had in amounts of 1. I have and use both of the DIYINHK devices, the XMOS and the CM6631A. I can give lots of information on the design decisions I made in the actual DAC.
NB: I'm terrified of public speaking, no hecklers (Mark) 😀
Here's the thread for my DAC: http://www.diyaudio.com/forums/digital-line-level/271388-nos-pcm1794.html
As far as the XMOS DIYINHK USB interface, I had some trouble with Ubuntu 14. It worked fine if you were happy with 44.1kHz. If you wanted some upsampling, things got a whole lot trickier. I sort of got it to work with Jack2, but I also wanted system sounds and Chrome sound to work. Eventually I just gave up trying to get ALSA and JACK to play nice and went back to Windows.
Linux: PITA to set up for upsampling and mixing
Windows: requires driver
OSX: just works
Just be yourself Tyler.
You are a natural at explaining things.
And what's a little ribbing among friends.
I'll pick on Dave while you are talking.
2016, Windows 10 and still no native USB Audio 2.1 support - oh, our Führer sucks.
Is Firewire death, I do not see it on PCs for a couple of years.
FWIW
My last dac was a single 1794 from Ross Martin Audio. It sounded good. I expect his dual 1794's sound great. It will be interesting to hear about what you've built.
If it helps instead of sitting down we should all just stand around. It will be less like "public speaking" and more like just having a conversation that way. There's no reason we can't do that.
Grant.
Grant.
Hi guys,
Has a date been set for this get together? Last I read the weekend of April 2nd or April 9th. Will this be a one day or two day event?
Thanks.
Thanks.
I just realized how soon this is. I was hoping to design a low noise high gain instrumentation amp to measure the noise and distortion of my DAC, but I don't know if I have time now.
Looks like a two day.
Are you planning on attending?
I'm interested in attending but it will depend on the weekend that you guys have picked which is still a mystery. 😕
Hi guys,
I've been away and out of touch. Saw Pierre's note that the facility is available either weekend (april 2 or 9). Which date is preferred? Either one can work for me. Let's get it settled and I'll send the invites!
John
John
Come on guys let's get this ball rolling and setup a date for this shin dig.
No shins shall be doug, or harmed in any way.
http://www.amazon.com/s/ref=nb_sb_n...i:aps,k:optical+thunderbolt+cables+by+Corning
Thought you guys might find this interesting.
USB optical cables.
I would call that a little bit of electrical isolation.
USB optical cables.
- Member Areas
- Clubs & Events
- The Greater Ottawa and Environs DIY Audio 2016 Get together.
