When I last ate ostrich I rather liked it, but then the whole pyramid scheme with ostrich in uk collapsed.
Referred to as 'Stewing hens' in these parts. Inexpensive and full of flavour."retired" egg laying hens to the stores. Great food.
I give them my own names. They vary in the thickness of blade, overall weight and bevel of the cutting edge. The thinner the blade, the less the angle.There appears to be more variety to cleavers than I imagined.
The Slicer is the thin flexy one. It has a nice 'ping' when you tap the blade. Veggies and flesh.
Combo is the next thickness up. If you have only one, this is it. Can do it all but somewhat limited.
Boner which can slice a bit but is better for bone joints and smaller bones.
Bonecrusher destroys the bones you intend to use for stock. Larger bones.
Beyond Bonecrusher you use a saw.
Just checking, whose flesh are we talking about?
Well Bill, like others, I have stories about the misadventures of slicing the wrong things, but this is a G rated thread so I'll leave it there.
We have an OTR combi unit and to be honest we rarely use it for anything other than the microwave. The oven function is slow to heat and seems to be cooler than what you set it at. We also have not had much luck doing the combi method of cooking.
Ours was bought as a Kenmore Elite so it's likely either a Samsung or LG.
😕 Yes, very mixed reviews on a number of sites. My SO is not very into technology so maybe the whole idea is too optimistic.
Then get some if you ever have the chance 😉
We may be a ways off for that. There may only be one publicly accessible tree here and it's close to an hour drive. I also don't see any place to buy the fruit. Lots of nurseries selling saplings or cuttings or seed stock but no markets selling the that I can find.
A friend of mine who is a jeweler and knows a thing or two about metal, does the opposite. He "pulls" the blade across the surface to deliberately create a wire along the edge, the with a series of alternating strokes breaks off the wire leaving a very sharp edge, which is also what a strop does. He start with, say, ten strokes on one side then ten on the other, then nine each side, then eight, etc, then once each side for ten repetitions.
I have tried it both ways and prefer my way to set an edge, and his way to finish it.
When learning to sharpen woodworking chisels and plane blades, I always heard that breaking off a wire edge left a ragged and weak cutting edge that would not hold up under use. The idea was to hone the blade until a slight burr was formed on the back side, then to flip the blade and polish that burr off leaving a clean, sharp edge. This was repeated with progressively finer grit stones to polish the edge. Sharp meant sharp enough to cleanly shave the hair on the back of your hand.
^BettermusicianthanI -- that was how I've learned as well (for both!), but going only to a pull stroke on the finest stone and strop (at an oh so slightly shallower angle).
And wherever it needs to be said, I do try to move my hands and wrists the least amount possible while sharpening and do most of the movement in elbows and shoulders. That keeps the angle much more consistent.
Leaving a wire edge and finishing off depends on the steel alloy. Chisels are usually used with force and thus use an alloy that does not chip easily so those are usually ground on one edge and then the back to finish off the resulting burr. Knives tend to be more flexible so some of their alloys tend to form a wire that can be polished off leaving an edge.
If you are really good you can sharpen an axe well enough to shave!
Needless to say I have a lot of sharpening tools as I have a lot of tools! (Still looking for a few more sharpening gizmos!)
I spent years working with stones and hones, carbides and wheels and while the edge was good, it took a long time. Time I no longer have to do that. The Chef's Choice diamond electric changed all that. I would never consider doing it the old way. I see no point in it.
Ed: still blunt. At uni we were tasked withr making tips for the tunneling microscope. The tip had to be a single atom. Now THAT is sharp.
I will be glad to let you run your finger along the edge to test for sharpness!
We may be a ways off for that. There may only be one publicly accessible tree here and it's close to an hour drive. I also don't see any place to buy the fruit. Lots of nurseries selling saplings or cuttings or seed stock but no markets selling the fruit that I can find.
It was a bit tongue in cheek, sorry. Honestly, it's good but a robust, spicy pear compote would be just as nice.
If they're anything like the AFM tips I've broken, it's too small to feel. Sort of like the flu shot I recently got: they've gone to small enough needles that they're on the threshold of sensation.
And, Cal, don't you *want* to see the point in it? 😉
I intend to use the back edge for coconuts 🙂
I use a drill for the water then a vice on the nut, for the mature ones.
For the young ones, the cleaver slices off the top to get the water and another whack downward from the top to split the body.
When you visit coconut growing places they like to take a machete for all that, please don't miss!
That's one of the 'misadventures with a cleaver' story. I wouldn't have tried it if I didn't see it done in D.R. and Costa Rica. The sad misses are when you go too far down and lose some of the juice. A perfect slice leaves a hole the size of a straw.
Tonight such a simple meal. Chicken wings, a couple dipping sauces, bitter melon and the real bacon. Eight days in the brine then one day drying in the fridge. I will do the same vinegar treatment for the skin, start it in the air fryer, then slice and pan fry. It's only a small piece as I am experimenting again. I am hoping it's not too salty. I don't want to use this bacon in a one-pot...
...again.
...again.
- Member Areas
- The Lounge
- The food thread
