Yeh, I don't even turn the soldering iron on here in Summer when we get over 32 deg C or so. My set up is in the garage and is not air conditioned, but it is just right in Spring and Autumn and some of Winter. If I start bringing stuff inside, my Wife gives me the evil look.
According to the two datasheets for the 2 transformers and my math - you are spot on Mike with that pin spacing to accommodate both the Jensen and Cinemag transformers for the next revision - I also like the elongated hole solution as well. Great work.Okay, here is a practice run of the Cinemag transformer layout. Feel free to look at it and let me know if you see anything off. I am just going off of Zen Mod's PCB plus the dimensions in the Datasheet. Instead of doing a two hole solution for J1/C2, I just made a slot that should accommodate both.
I also support the mod Vunce has suggested in post #258 when using the larger diameter electro for C1.
Keep up the good work.
Good looking assembly, Vunce, and good observations.
The Muse capacitors are the largest diameter part that are likely to occupy the C1 and C2 locations. I elevated the larger power resistors an extra mm or two above the PCB to allow more air circulation. That would also help prevent R3 from getting too warm. My choice for R3 was one of the larger diameter parts available for that position. It should run reasonably cool.
I will build a pair of the new PCBs and will be paying attention to component clearances. We should have a little more wiggle room without the zeners. Plus I really want to hear how the CineMags sound in the F6.
Okay, done 🙂 Your progress looks great!Some more progress....
Heatsinks are prepped and F6 Diamond boards are built, minus the OS Fets.
The right channel board has a tight area around C1,6,7 and R3. The Nichi Muse cap is 18mm diameter and is very close to R1, if this resistor gets hot it might be a concern.
@Mikerodrig27, if you plan to remove the zeners, maybe shift the LEDs, trimpot, R4, R9 and R3 down the board a few mm’s that Z1 used to occupy, if that’s possible. That would give some breathing room between R3 and C1. The left channel is good.
What’s progress without porn…😆
Fantastic work Mikerodrig!
These revisions will give builder lots of options, well done.
I ran across this photo while reading up on the F5.
I think we have a good solution to stacking the resistors for R1*.
Hi TA, do the Toshiba transistors Q9-U3 need small heatsinks?
Nice layout Mike, might have to get these as I have some Cinemags's on order.
@Mikerodrig27
Referencing to post #265, you might consider changing the silkscreen for U3 to something like Q10. You should also change it in the F6 Diamond schematic.
It just looks odd since the TTA004B bjt transistor isn’t a regulator.
Best,
Anand.
Best,
Anand.
Okay, Schematic and PCB changed to Q10. Thanks for catching that.@Mikerodrig27
Best,
Anand.
I have looked at that solution many times over the years and the sticking point is that they all involve specialized tools for crimping the connection pin/socket, and oftentimes installing and😱r removing the pin/socket. The cost of the tools are not affordable for nearly all hobbyists.I think if you want to have the more modular approach, I would use some sort of connector with a wire lead hanging off of the end. This might even be a better approach as you can have a wire set with connectors coming off of the power supply, binding post etc always be the same length. Then the wired connector coming off of the amp board can be tailored to the connectors in the case. The amp board connections are never in the same spot as other amp boards.
I gather there is little or no support for terminal blocks or other on-board connectors. I think we can let my suggestion die.
I have looked into pcb terminal blocks that will fit the board for the loudspeaker and power supply connections. Both of these below will fit the pcb.
2 way terminal block 10mm pin spacing - Mouser part number 571-282858-2 will fit for the loudspeaker connection - rated at 24A for wire 0.5 sq mm to 4 sq mm.
3 way terminal block 7.5mm pin spacing - Mouser part number 651-1988118 will fit for the power connections- rated at 32A for wire 0.5 sq mm to 4 sq mm.
Nice sleuth work Gary.
An M3 fastener almost fits through those holes, very close. I was investigating if using brass standoffs screwed through the bottom and soldered to the board would work. It's a mounting scheme that EUVL uses for his boards, it works great for my M2OPS amplifier.
Edit: The standoffs in the pics are M4 size.
Yes, the pcb holes are a bit bigger, but they can be carefully filled with solder around the 1mm terminal block pins.
Your suggestion Vunce, is another solution.
- The F6 Revisited
