The F6 Revisited
The boards I’m currently playing have ceramic caps bypassing the voltage references and MKS caps bypassing the local power rails. Seems to be a good combo.
The IXTQ75N10 Mosfets have broken in over a few days. Presentation has smoothed out and is very enjoyable. Spinning some vinyl for the first time in a while; the F6 has developed some of the better aspects of a fine tube amplifier.
Do we ever take the easy way Gary? :rofl:
Ok, 68R for gate stoppers
I was prepping to use 3K for R7 and R8, did you find this value was too much current through the LED's?
Then I'll shift to 3K6.
LTL2R3KGD is the part number of the LED's I will use, they have the same forward voltage (1.96v) as the LTL-4231N's that were tested.
Thanks TA!
OK, I have checked the matching on the KSA992FBU and KSC1845FTA transistors I have here.
For the KSA type, the min Hfe was 462 and max was 520. For the KSC type, the min Hfe was 408 and max was 456.
Out of all that, I got 462 & 466 for KSA and 456 & 456 for KSC for one channel - that is 2.3% match. For the other channel I got 467 & 469 for KSA and 455 & 455 for KSC - that is 3.1% match.
While I was at it, I also checked the Toshiba TTC004B and TTA004B
For the TTC type, the min Hfe was 175 and max was 245. For the TTA type, the min Hfe was 183 and max was 247.
For the left channel I picked TTC at 221 and TTA at 221 - perfect Hfe match.
For the right channel I picked TTC at 222 and TTA at 225 - 1.4% match.
Let's see how Vunce goes with his matching, for all types tested it was easy to get multiple pairs prefectly matched N to N and P to P. It is the N to P matching that is hard to get perfect. I tested about 50 of each of the 4 transistor types using a Peak DCA75 pro tester.
