The diyAudio First Watt M2x
Joined 2002
I reckon yet another thing to learn from that story is - if you see some misterious things happening and start suspecting issues like bad batch of PCBs from diyStore, mislabled resistors from Mouser or something even more gruesome, - pause, make 3 steps back and look into the mirror - "*we* are the gremlins", as ZM once said...
ZM can be a bit facetious at times. :joker:
I am a software developer, and we have a very frequent saying: “I found the problem!, it was between the chair and keyboard!” :)
Yeah, it’s usually man-made errors rather than crazy scenarios where a weird printed PCB met a mislabeled part that had an internal malfunction. Human error is much more likely, always. That doesn’t mean the other things don’t happen, but they happen less often.
Joined 2019
Yes this is great advise. Some of us have been screwing things up for so long that the process of eliminating all the errors I could have made before suspecting any thing else is deeply ingrained in my trouble shooting flow chart. If it has more than two parts it is possible for me to get one wrong. I just embrace it and smile.
question about sparkfun adapter
Does the sparkfun adapter turn the smd 180º from the way it would solder directly to the board? The one on the right in the photo has the square pads lined up. I finally got around to putting these adapters together with the opa1611 and this is confusing me. I've tried Austin, Cedarberg, and Tucson with the opa604 and lt1122, now I want to try the opa1611. I wish we could buy these daughter cards in individual pairs, somehow I lost one Norwood board. I'm currently enjoying my F6 (led bias mod and IRFP150) now that it's cooling off here in Austin.
I have a question about the Ishikawa card.
I tried to bypass C1 but had a few mV offsets.
This can be reduced on the M2 Tea-Bag's PCB by installing a 20R pot as shown in the picture.
Can the same be done on the Ishikawa card by installing RV1 = 20R instead of R1 and R2? Then set 0r on the Edcor input?
Joined 2005
I have a set of M2X boards [A & B]. Not sure how I ended up with one more set than I needed to build my amp. Though it is often helpful to have a bare board to refer to once you are deep in the weeds.
I'd like to pass these on for those starting this great build adventure, which is guaranteed never to end with all the new cards.
If interested, send me a message. I just ask for $7.00 to cover shipping, payable to my PayPal account.
The question is still open :)
I had the Mountain View card for half a year. Yesterday I launched M2x with Tucson. The first thing I had to do was set the offset. It was 120mV. It floats definitely more, but I managed to set it to +/- 5mV. The opamp is LT 1122. I am a bit worried about the high temperature of the opamp because it burns my fingers quite quickly. The listening comparison is not ready yet. IMG_20211014_203937.jpg
Hello All,
I just finally got around to finishing up on my MX2 build. But I have an issue with one of the channels.
I have about .744v dc present at pin4 and R5 on channel A and this is not present on the other working channel. I am a bit lost where to go from here to locate the issue. This is also present with the daughter card(s) removed.
so far:
R13, R14 - 0.630v
offset - 0.0v
PS - 22.5v +/- on both rails
Sound does come out of this "bad" channel but its not good or even close to the other channel in volume or quality.
Thanks in advance to anyone that can help point me in the right direction.
Yes I did swap the cards between channels and they work on the good channel B and the same issue is present on channel A.
Ishikawa - W/ Toshiba jfets from the diyaudio store
and thank you for the quick reply.
Quick note: I am using a T style heatsink and the connectors have been moved to the underside of the board
Ishikawa board C1 question
i´m just in process of ordering parts for M2x Ishikawa Iteration.
When i crosschecked the mouser parts (actually im ordering from reichelt in Germany) i came across a probelm.
C1 (Ishikawa board) is specified by Mark as "nonpolar", preferred is Nichicon green sleeve (Muse?) but all the C's i find are polar ones : (
The symbol for C1 in schematic shows two equal thick lines, indicating nonpolar.
And yes, of course, it shows that my knowledge is too poor to understand what C is asked for electrically in this situation :D
So the attached ones seem to be wrong, right?
tnx very much,
stefan
