PaulInWA,
Check Newark.com
Why turn to eBay when Newark has plenty of IRFP240’s?
Also check there for the other out of stock items.
YMMV, but my very limited experience with Newark is not good.
- Connectors arrived in a padded flat pak, but the tabs were broken off. All of them.
- Components ordered and arrived, but the quantity was off. Even the pick slip confirmed that I didn't fat-finger the order.
I will order from Newark in the future, but only because I haven't ordered from them much, and only if they are the last resort.
Kind regards,
Drew
to Rysssen
Hello Ake,
yes, you should arrive at around +-10.5 V DC to +-12 V.
25 V DC on one of your rails is definitively too high. The 300 Ohm resistor should burn that voltage down to the before mentioned values. And V DC should be symmetrical on positive and negative side.
Greets
Dirk
Hello Ake,
Greets
Dirk
I got a hold of a pair..Anyone got 1 extra Black forest pcb to sell to me?
- The diyAudio First Watt M2x
