The Class - H Amplifier
Class-H is much efficient than Class-AB, but don't compare it with Class-D which is totally different thing.
Having made Class-AB/H/G/D, Class-D gave me highest of efficiency and reduced Heatsink size.😉
ClassH is 8-10% more efficient than a good class AB design.
No MUCH more.
And less distortion compared with any switching amplifier design, even ClassI.
"ClassH is 8-10% more efficient than a good class AB design."
True, when driving sine waves.
On music with a high peak-to-average ratio it's a different story.
Have you ever been inside a Carver M1.5T?
2x 600W/4R and NO HEATSINK.
Distortion?
On music with good program material and associated gear it sounds at least as good as well respected class AB designs. The non-inverting version of the Carver M1.0T sounded even better than the M1.5T
With the better commutation diodes available today these designs can be even better (than the older designs).
There are of course poor designs of all types. A class H design from NAD didn't sound that good, even though you were listening well below the transition point (the lower rail was ±60V, enough for 400W/4R peaks while still in class AB).
Hi Folks,
Here's my Complementary Vertical Mosfet Class-G amp....high efficiency in real music signals
Hope you like it.....
I am preparing the PCB's.... for my car amp.
All Tansistors are CB 2N5551/5401 & EF BC556/BC546
Mosfets IRFP540N/9540N
Opamp NE5532
Schottky's MBR160S
Rails are +- 30V, +-60V
Load is 8 ohms
power is 150Wrms
BW 150KHZ
Sine wave efficiency is around 80%
regards,
Kanwar
Shown here is conceptual schematic not actual one
