It's not a problem, it's normal. Usually there is a coupling cap in a DAC (0.01uF or similar) and you don't have to do anything. If DAC does not lock to your transport, install such coupling cap at the output.
Thanks Peter. My DAC communicates with the transport without any problem. I am just thinking if this constant voltage is not dangerous to my DAC when used for a longer time..
I got my birdnest setup running today with the original trafo and a Vishay W02G diode bridge with a Evox-Rifa 1nF cap between each leg. Two Panasonic FC 1000uF / 25V caps and a MC7808C regulator. The C916 was replaced with a Panasonic FC 22uF / 100V cap.
The two output resistors were just some old ones taken from the drawer.
The 5 components suggested by Peter was removed.
The transport is feeding a DPA Enlightenment DX32 DAC.
It´s cool when it works the first time, but I can´t comment on the sound yet until I try it up against my DPA transport.
Iwok: its not dc voltage - its the spdif signal, which is so fast that your dmm thinks that its dc.
any reason why u need such a large deviation from the original value for C916?
Commstech, no reason other than Peter recommend a 33uF or 47uf BG but I only had a 22uF if I wanted a Panasonic FC.
I´ll see if I can find some BG´s to experiment with another powersupply.
Thanks Peter. You provide solid, easy-to-follow guidelines for this project.
If I may, I suggest putting a .27Ohm - .47Ohm 2-5 Watt resistor between the LM7808 V+output and the 1,000uF-470uF decoupling cap that follows it. LM78xx regulators are notorious for oscillating into low impedance loads and a low impedance cap like a large value Black Gate or Rubycon (esp. with a bypass) after a commercial regulator will result in oscillation. The added benefit of this resistor will be to provide a last low-pass RC filter for the supply before it reaches the active components. The resistor does not need to be low-inductance, in fact, inductance would add further HF filtering, which would be beneficial here.
Help
That is my exact problem....
So excuse me for being 'a bit of a thicky' (there is no excuse really!) but... the (0.01uF or similar) cap goes across DOUT and GND after the output resistors? Or in line on DOUT?
DAC locks on to other sources OK. Using the built in DAC in an Onkyo Integra A-701 for now.
I can only think of electronics by using plumbing analogies, this will only get me so far I guess!
I'll probably have found out by the time anyone answers..... I'm on Japan time and at the start of the Labour Day holiday here.
regards all
Bill
regards all
Bill
... the (0.01uF or similar) cap goes across DOUT and GND after the output resistors? Or in line on DOUT?l
It goes in line with output, after the resistors.
Thanks Peter,
I tried that and still no lock. DAC still locks to another source all other things (cables) being equal.
I'm still using dubious output resistors (measured values are close to 300 and 100 Ohms) I had lying around, I'll try swapping them out for the better ones I acquired.
Any thing else to look for folks?
thanks
Bill
It could be something else with a transport, most commercial DACs are AC coupled and offset from a transport shouldn't be an issue.
Bill,
At a certain moment while tweaking mine I experienced a lock problem because I had some power supply cap leads crossing over the SPDIF wires. When it happened, a friend of mine suggested me to keep other voltage source far from SPDIF wires. Moving them away a few mm cured the sync problem right away.
Yes, I am suspecting some other problem to turn up....
The analogue outputs from the on-board DAC are fine (I've heard worse, to clarify) I should check Dout traces back to the chip I guess. If I scope the SPDIF signal what kind of trace should I expect at what settings? I can play a test disk 1K square wave or something... Asking basic questions I know
Tried moving signal and power lines seperate.
I should swap out those output resistors next....
Or start 'divining' with a coat hanger perhaps!
No..., that approach is for much later in the day!
I appreciate all the help and advice thanks! Hope this may help some other 'electronically challenged' music lover in future.
Bill
Bill
Digital Lock
Dear all,
I changed the output resistors and the DAC locked right on there...🙂
Now to try another DAC I can use in my current set up to finally see how it sounds through digital out....
Thanks again for the ideas people.
regards
Bill
Dear all,
regards
Bill
Very impressed
Just a quick note to say I am still very much impressed with the sound from this machine a week on...
Now I need to build a good DAC....
Santa Claus, if you're listening?
I've been a good boy (kind of!)!
Bill
Bill
I measured it once and IIRC it was prrox 250-300mA at start up and about half of that at normal play.
- More Vendors...
- Audio Sector
- The CD Transport
