The Best DAC is no DAC
Do you have a mute board, if not I can probably let you have one leftover from an earlier nodac project. It's the board on the left below;
PM me if you want one.
hi
I've been following this post since the beginning, I have this XMOS circuit.
yesterday i try again to build simple LPF, but this time i add isolator and battery PS. the sound is VG.
the pop sound is very high!! i connected the mute leg to the ISO EN leg and its help but when i change format i have pops.
still have hiss noise, want to add 74hc74, do you think the flipflop Could lower the hiss noise?
thanks merlin el mago
my cutoff frecuency is~18Khz, its too low with first order 20nf,1kohm.
now its work with no flipflop, only ISO7640. i use iriver 4*DSD.
Something managed to solve the problem with the pop (bomb) when change between DSD file to PCM file?
ok last night I do some test:
what I increase from 1*DSD to 4*DSD the noise Floor increases by 5db.
I replace the pc PS to batt and the noise from down from 50db SNR to 60db.
still here hiss noise, but low.
try to figure what is the problem source
...its much to read...and its an amazing idea
Hi
I am interested in build up a converter as you discribed,
PC - USB - "Best DAC is no DAC" - Preamp (XLR) -LS
i go throug a lot of pages put is it possible to get a summary of all latest parts and /or i kind of material of quantity (MoQ)
chris
