No stress here Ray. I'm perfectly happy to make a minor alteration. Please don't beat yourself up. You've been more than kind to allow us to join in your latest audio experiments and to go to the hassle of arranging the logistics of it all.
Thanks again,
James
Thanks again,
James
Another confirmation that I am happy to mod the current board myself. It was a kind offer though, so thanks.
Hey, guys thanks so much for the support, now I'm embarrassed by all your kind comments
I found some time this morning and have been assembling a board and taking some pictures so I can document the modification. I'll post it later. I've almost finished the board so will be able to test it a bit later - I'll let you know how it goes.
Thanks again for the positive comments.
Ray
Ray
Hi Nautibuoy,
i too will be ok even with such a little modification.
Thank you for your efforts.
PS: don't know yet if i received the board.
I'll tell you.
I'll tell you.
OK, some good news🙂
I've assembled a balanced board and have just been testing it; with the modification everything works fine, producing very nice music. The only thing I haven't tested is the mute function and will do that a little later.
I actually tested it in my Silk TVC project. I assembled the PCB with a LP filter at 40KHz then took the outputs from the board straight to the Silks, with no caps. It works well and all of the white noise/mush is gone, background is now really quiet. Music sounds wonderful.
So, if you make the mod to the PCB you should be fine.
Here's a walk through of the modification for anyone who isn't sure about doing it.
Step 1. Cut the PCB tracks like this;
Step 2. Solder the header sockets to the bottom of the PCB (I install them onto the JLSounds board and then solder a couple of pins in situ to make sure everything is aligned) but DO NOT solder pin 1.
Step 2. Insert the 1N4148 to the PCB and jam a length of fine wire into the pad nearest the board edge and solder the pad. Slip some sleeving over the wire and bend it around pin 1 of the header socket. Solder pin 1 and the wire to the PCB. It should look something like this (n.b. I routed the wire to allow the screw terminal to be soldered to the board later);
Step 4. Turn the PCB over and, using the wire from the 1N4148, make a connection in a similar manner to the screw terminal pad. Bend the end of the wire at 90deg and push it into pad. Like this;
Step 5. Insert the screw terminal to the board and solder. It should end up looking something like this;
And from the top;
Hope that helps.
I feel a bit more chilled now.
Ray
And from the top;
Hope that helps.
Ray
BTW, the board I assembled uses the higher output current FlipFlop that I mentioned a few posts back. I can't honestly say if it made any difference as I also incorporated the LP filters at the same time but overall this build is a dramatic improvement over the previous attempt at using the Silks as the LP filters so the new FlipFlop doesn't seem to be doing any harm.
I'll measure the DC across the FlipFlop output later too.
Ray
Ray
Hi Ray
I have receive the boards. Thank you so much.
No worry about the minor bug. This is really a minor and will not make any sound degradation.
thank you again.
Br
Caad
thank you again.
Br
Caad
Just to confirm that I received my boards as well, thanks a million!
Ray, you did such a great job with the GB, don't you worry about two traces. Anyone who can solder the parts on the board should have absolutely no problem taking care of that...
Good stuff Ray 🙂 Do you reckon your improvements are due to the flipflop giving approx double the output volume with better signal to noise and not requiring the dc blocking caps in the signal path?
That seems probable, though I can't demonstrate it as I haven't really progressed the projects in a controlled manner, making several changes at a time and only measuring the results with my ears. Makes me smile though.
Ray
working in progress
Hi, friends, I checked on my flip flops card, modified as Ray said , and for the right channel I have 0v between + and - (2.5- and 2.5 +) but on the left the 5v (+ 5V and 0-) this without music coming out. Fabio.
I have measured DC across the +/- outputs of my balanced board (just powered up, no playback);
Right = 0.1mV
Left = 0.2mV
Ray
Right = 0.1mV
Left = 0.2mV
Ray
I have also successfully tested the mute function although not with Fabio's delay circuit (because I forgot to order the preset potentiometer).
Anyway, having made the PCB modification I now have a correctly functioning balanced (FlipFlop) board that is producing great sounds.
I did check the DC offset across the outputs with music playing and, not surprisingly, it does fluctuate but I didn't see it go above 4mV.
Ray
Ray
How's this looking now Fabio?
Have you checked for solder bridges? Maybe start by checking continuity to see if the left positive line has a connection to the 5V line?
Ray
- Digital Line Level
- The Best DAC is no DAC
