Hahaha!! Definitely can get as loud as the Mustang 😀
Thanks X.
Zman,
Believe me, I want stereo also...
Thanks X.
Zman,
600VA trafo! Wow that is a bruiser! Must weigh like 17lbs for the trafo alone?
Very glad it is working out to be silent with no signal playing. Always tricky when you attach everything all together in a chassis to have zero hum. What are the heatsink temps with fan run I g and the middle one with no fan?
Hi May i know if I can mount each of the output devices on a Conrad heatsink size 250Lx50wx155H, instead of going thru the CPU fan way. So effectively 500Lx155H on each channel.
Will that be adequate heat removal for this ABBB amp?
Hi Meanie,
What is the delta-C/Watt rating of the Conrad? Each output device dissipates about 100w, your heatsinks might be able to handle 75w is my guess, but the bigger concern is the spreading of the heat flux from the small contact patch out to the rest of the sink. That’s where heat pipes on the CPU coolers come in - they conduct heat 100x to 1000x better than solid copper. You may have a local buildup of heat that will make the MOSFET hot, locally. You can try it - use the ceramic thermal spacer and good heatsink paste compound. Have an IR thermometer ready to measure temp of MOSFET. As long as it is below rated max safe operating temp (probably 150C?), it can work. That’s a lot hotter than we normally run MOSFETs but I think that’s how they run in some industrial devices. Those devices are actually pretty tough.
The heat pipe and CPU coolers on the other hand keep the actual CPU below 80C.
But I don't think it would be unsafe to try the Conrad if you have it already - just shut off if the temp exceeds say 130C.
Hi X, I have your pcb's, just about all the parts ( I don't start a project till I have all parts on hand, that way the build is quicker), I then will check all resistors, double check Fet matching. Just waiting on the Toroids which have been ordered. I then reread all the notes and printouts I have done from the thread with handy build and testing/biasing info, put all of that in logical order, in a folder, double check all parts against the latest BOM.
I have the enclosure ready to go, so anticipating my build on this project for early in the new year as I have a few things to finish first and make space on my bench - as well as a way overdue tidy up.
I’m slowly working through soldering in between other projects. One question. Are there any components that require / would benefit from matching? From the original ALPHA BB thread it appears the KSA992FBU (V101, V105) should be matched? Of course, I just got done soldering these as I thought about it 🙂
Greg
Greg
X, thanks. Just to be clear, matched on hfe? Any preference if they should be selected low / high in the distribution of hfe? Also any benefit in thermal coupling them w heatshrink or something more elaborate?
Greg
Greg
Yes. Simple Hfe match (actual value not critical) with transistor tester. I use shrink tube to tie them together for thermal bond.
Hi X, I have been looking through this thread for the latest schematic with any updates and corrections after you built and tested the pcb. I found a few BOM's from various members - but do not seem to be able to find the as built and tested schematic. Could you post that again at your convenience, thanks.
I have been gathering parts and want to make sure I have everything as required to build my stereo pair of pcb's, thanks again.
Regards,
Gary..
Regards,
Gary..
Thanks X, you showed a schematic at post #1, but that was before any pcb's were made, so I was hoping there is a final as built schematic some where that I can compare the various BOM's to. I am sure that will help other members who are going to complete this monster 😀
Gary..
Gary..
Hi Gary,
This is the “as built” (by me) parts list for a single channel ABBB.
Double it for a stereo build.
Best,
Vunce
Mouser Electronics
Best,
Vunce
Mouser Electronics
- Group Buys
- The Alpha Big Boy with Buttah (ABBB) 52w Class A Amp GB
