The Aleph30 PCB layout
If there is more interest with those boards, I could make another run. Just send me an e-mail showing your interest ( A30 boards as subject). It has to be at least 20 pcs total.
I didn't abandon input module board project for AlephX, it's just that presently I'm tied up with manufacturing Patek amps. If those are done, I will have more time for more personal projects.
hello peter
Just take it easy with the X-input bords - I was not intending to push you in any way - after all, one has to put butter on his bread ;-) ....although I have doubts about how much "butter" you can make on the patek amp, considering the amount of work it looks like you put into the amp - it does not really resemble a "one hour piece of work" if may be so humble...!!!
Keep it up !
Cheers !
Buhl
Since I'm still receiving inquiries about A30 board, I decided to make another production run (however, in smaller qty than previously). This raises the price a bit, so the the board containing 2 channels is $25 now (2 pcs. or more $20/pc), shipping included.
Please send me an e-mail (subject: A30), and I will provide payment info. If enough payments are collected this week, I will have the boards available in two weeks from now.
A30
Peter, do you think your board will work with the updated J-fet mod? I haven't had time to read through all the threads but Nelson's recent article on power J fets got me interested again in the aleph design. I am assuming that the inputs are also j-fets.
I have built the Aleph 1.2's back in 2000 and they run hot but I never tripped the heatsink thermistor. I measured my heatsinks right around 50 degrees C, They are giant amps with all the heatsinking, 2kva tranny and 8 20k-75w caps C-L-C supply. thanks, dave
Re: A30
jh6you said:
And, looks very crowded in a small area, any merit by making so. . . ?
To paraphrase the famous quote: "Everything should be made as simple as possible, but no simpler" , I tried to make the layout as big as required, but no bigger 😉
Anyway, it seems like this is the best sounding Aleph I've built so far, the small board size allows easier integration as well:
I'm not sure about that, but if it's a regular Aleph configuration with just different devices and maybe few other parts changed, it might work.
Wow. looks very special. I like it.
By the way, in general Class A DIYers are to consider the heat and its efficient distribution. For whom wants to make the chassis like the original A30 shape, probably, the layout might be too much centralized.
jh
Just to refresh the subject, the boards are available again.
Nope, the Aleph-J has Hitachi (or Toshiba) J109 (If memory serves me!) dual fets in the inputcircuit. (two small fets in a single package) Otherwise it might be as an Aleph. That little device has 7 legs, pretty close together😀 I dont think you can pop that into Peters boards:xeye: On another note, The Aleph-J has nothing to do with PowerJfets. That would be the F3, which is a different story🙂
Steen🙂
