System Pictures & Description
The frequency sweep looks excellent. You must have designed it well. How did you make your design choices?
Traveled around and heard many different solutions and chose what I think sounded best on music.
However, such measurements cannot be reached without a well-treated room. That's the most important part.
Look at the waterfall from 50 - 150 Hz. It requires a good job with the room.
The room has many self-assembled solutions, and first reflections are under very good control
Another important thing is the choice of a good DSP solution.
I use Audiolense
I saw your design rationale on your sub thread:
My philosophy is lot of membrane areas and low stroke. It produces little distortion.
I think it is important with low group delay.
The room is also very important, and it is important to work for short reverberation in the lowest bass
Can I ask about the "6 pcs. Acoustic Elegance TD15M in OB - midbass from 60 - 500 Hz" please?
Is OB short for open baffle?
Were the TD15M originally meant for a sealed box?
Did you put the TD15M in a sealed box?
If so why change and how does it sound?
Thanks for posting your photos and measurements of your super system!
Thanks, we think a lot in the same way:)
Yes, open baffle.
Would never reach such a waterfall with a closed midbass system
At a slightly earlier stage, when there still was some trouble with the midbass, but pretty good control over distortion
..... Yes, open baffle.Would never reach such a waterfall with a closed midbass system
Your waterfall is a thing of beauty. Its so clean. So OB mid-bass reduces resonances? Seems obvious now I think about it. Thanks for the tips.
The waterfall is so good it makes 34Hz loom large. Is that from the eight PD.2450 resonating, or the six AE-TD15 or something in the room?
766739d1562438749-system-pictures-description-vannfall01-jpg
Titan
Finished this project last week. The drivers are LCY108 tweeters, HM130Z4 Audax mid-ranges, and Aurium Cantus AC250F1 woofers. The woofer is in a sealed enclosure and the M/T above it is OB. The series crossover is at 300 and 4k. Wood used is Rosewood veneer and Wenge, finished with 4 coats of Waterlox. Sorry about the pics, wish this had a way of rotating them.
The Windows Image Viewer has that option.
You have to rotate them before uploading them to the forum.;)
Congratulations for the monster.... : :) :eek:
Reactions: 1 user
Some pictures from the midrange Construction
140 kg
SSA-WG speaker project
I completed my speakers that I have been working on for quite some time.
A few details;
Name:
The SSA-WG is a 3-way Scan-Speak Accuton WaveGuide project.
Drivers:
Woofers: 2x Scan-Speak 22w/8857T00 (parallel)
Midrange: Accuton C173-6-090
Tweeter: Scan-Speak D3004/6640 mounted to a Jantzen Waveguide
Crossover:
Duelund with approximate crossover frequencies of 300Hz and 2150Hz
Details can be found linked below
Introducing the SSA-WG
It was quite the journey. It was my first design from scratch. I used Soundeasy for crossover design. Learned woodworking skills along the way.
They sound very good.
Here's a few pics.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Reactions: 2 users
I used the vertical type and that's also what I have seen most used. It's very hard, you need good sharp tools. Really no dings during the build. Here's a few pictures. The top is stacked end pieces to highlight the bamboo ends. I find it an excellent material for speaker building.
attachment.php
attachment.php
Reactions: 1 user
Compared to a lot of what I've seen here, fairly simple, but it gives me exceptional quality and stereo image, so I really do enjoy my music.
Pair of MTM speakers, custom designed, sealed for now (Q=0.84, IIRC). Based on Visaton W170S and SC10N, likely change to Peerless tweeters (can't remember which right now).
Source is a PC with a Creative Sound Blaster X-Fi Fatal1ty, connected to my own design 330 W (4 ohms) via a lovely QED J2P.
