System Pictures & Description
The frequency sweep looks excellent. You must have designed it well. How did you make your design choices?
Traveled around and heard many different solutions and chose what I think sounded best on music.
However, such measurements cannot be reached without a well-treated room. That's the most important part.
Look at the waterfall from 50 - 150 Hz. It requires a good job with the room.
The room has many self-assembled solutions, and first reflections are under very good control
Another important thing is the choice of a good DSP solution.
I use Audiolense
I saw your design rationale on your sub thread:
My philosophy is lot of membrane areas and low stroke. It produces little distortion.
I think it is important with low group delay.
The room is also very important, and it is important to work for short reverberation in the lowest bass
Can I ask about the "6 pcs. Acoustic Elegance TD15M in OB - midbass from 60 - 500 Hz" please?
Is OB short for open baffle?
Were the TD15M originally meant for a sealed box?
Did you put the TD15M in a sealed box?
If so why change and how does it sound?
Thanks for posting your photos and measurements of your super system!
Thanks, we think a lot in the same way🙂
Yes, open baffle.
Would never reach such a waterfall with a closed midbass system
At a slightly earlier stage, when there still was some trouble with the midbass, but pretty good control over distortion
Titan
Finished this project last week. The drivers are LCY108 tweeters, HM130Z4 Audax mid-ranges, and Aurium Cantus AC250F1 woofers. The woofer is in a sealed enclosure and the M/T above it is OB. The series crossover is at 300 and 4k. Wood used is Rosewood veneer and Wenge, finished with 4 coats of Waterlox. Sorry about the pics, wish this had a way of rotating them.
The Windows Image Viewer has that option.
You have to rotate them before uploading them to the forum.😉
Congratulations for the monster.... : 🙂 😱
Reactions: CLS
Some pictures from the midrange Construction
140 kg
SSA-WG speaker project
I completed my speakers that I have been working on for quite some time.
A few details;
Name:
The SSA-WG is a 3-way Scan-Speak Accuton WaveGuide project.
Drivers:
Woofers: 2x Scan-Speak 22w/8857T00 (parallel)
Midrange: Accuton C173-6-090
Tweeter: Scan-Speak D3004/6640 mounted to a Jantzen Waveguide
Crossover:
Duelund with approximate crossover frequencies of 300Hz and 2150Hz
Details can be found linked below
Introducing the SSA-WG
It was quite the journey. It was my first design from scratch. I used Soundeasy for crossover design. Learned woodworking skills along the way.
They sound very good.
Here's a few pics.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Thanks Dave, I don’t think bamboo has a grade like Baltic birch...I could be wrong. I used 1” thick cross laminated vertical grain carbonized bamboo ply. There were some small voids on the edges I filled with epoxy. Hearing from others it’s kind of hit or miss on the consistency.
Scott
It does, it comes in horizonatl, vertical, and stranded varietes. I do not recommend the horizontal, probably not as good (but not as pretty) as good BB. Vertical is what i find most used, stranded thou is better by a long margin, and has a much tougher surface as far as collecting dings goes.
dave
I used the vertical type and that's also what I have seen most used. It's very hard, you need good sharp tools. Really no dings during the build. Here's a few pictures. The top is stacked end pieces to highlight the bamboo ends. I find it an excellent material for speaker building.
attachment.php
attachment.php
Compared to a lot of what I've seen here, fairly simple, but it gives me exceptional quality and stereo image, so I really do enjoy my music.
Pair of MTM speakers, custom designed, sealed for now (Q=0.84, IIRC). Based on Visaton W170S and SC10N, likely change to Peerless tweeters (can't remember which right now).
Source is a PC with a Creative Sound Blaster X-Fi Fatal1ty, connected to my own design 330 W (4 ohms) via a lovely QED J2P.
