System Pictures & Description
I used to share my stereo speakers between a 2 channel and a surround system, but now use them for stereo only records, and added a proper source switcher, to use a second blu-ray player in it for music videos or old movies, and streaming through an inexpensive Topping DAC, in addition to an old CD player.
I am using a pair of Fosi mono blocks now, and aren't sure about them yet, and like the Fosi Box X5 bought at the same time, but will continue to use a kit 12AX7 phonostage I've been used to for years from Little Bear, a T10 version 2.65. A wire from its V3 tube cover to its ground terminal eliminates any hum I can hear at much louder levels than I use.
The stereo pair sounds better after a new crossover. It's all first order, with chosen to both minimize comb filtering with a shallow slope crossover, and coincide with the main dipole peak. The drivers are on the inside, and no toe in is used, to keep the large baffle reflections away from me somewhat. The old Sansui woofers are from a sealed model, and play a bit lower with new lighter foam surrounds.
I have an Advance Paris A12 integrated amp, TEAC VRDS-20 CDP, Wiim Pro Plus streamer, B&W 703 S3 speakers, recently rebuilt Quad ESL-63 speakers, and an SVS 3000 Micro sub. My LG 77" C2 OLED TV is driven by an Nvidia Shield TV Pro, is also hooked into the system, and I use a Sofa Baton to control things. Finally, there's a PC connected to the audio system and the TV to generate visuals that sync with the music playing on the system.
The listening chair for the Quads- I'd rather have the Quads at this end of the room so I can see the view while I'm listening to them. The room is 16' wide, and it's 28' to the island in the kitchen. The ceiling is 11 ft high with big HVAC duct, big wood rafters, huge wood beams and posts, and plenty of sprinkler pipes, track lights, and electrical conduit. It's a real mess up there!
I just got the rack in the photo, and there's a new chair coming next week, so I'm still figuring out where to put everything. I'll hide the cables better once things are finalized. The rack is definitely oversized for my small collection of gear. I may look for or build something smaller. My favorite analog playback device, on top of the rack, is an Edison Model B cylinder record player.
The computer runs MilkDrop 3.26 to generate visuals synced to music
I just finished rebuilding the Quads a few weeks ago, and made the stands for them. They sound fantastic!
Love the sound of the Quads, great iconic speaker!
I've been trying some near-field experiments with the Quads. I started with them parallel, a couple feet from the chair, like big headphones. The soundstage was like headphones, too- everything was inside my head. I moved the a bit forward and toed them in- better, but centrally mixed sources still sound like they are in my head. I'll try moving them a little farther forward next. They sound fantastic!
Here's my hot GF trying them out:
I haven't, but this is what Stereophile measured:
If you are referring to the response above 10kHz, I'd say yes, it appears they roll off. I'm 66 YO and haven't been able to hear much of anything above 10 kHz for at least 10 years. But you know what? There's not much up there in music to hear, and music still sounds great. When I rebuilt these speakers I used 3 um film for the diaphragms and Licron Crystal for the resistive coating, which I believe is a bit thinner and lighter than the original diaphragm and coating, so maybe I'll get slightly better response than this in the top octaves. Even if I do, I won't be able to hear it.
I have REW and a calibrated mic. At some point I may figure out the necessary connections and try measuring it.
Hello guys, I wanted to make a 2-way speaker because I got bored with the size of my "Troel s Seas 3 way classic II" speaker that I made 10 years ago. The result is a speaker that fits the size of my living room and sounds great to me. I am currently listening with a Primare i30, but I am sure it will sound even better with the Pass F6, which I am tired of taking out of storage, with its huge body. Sensivity around 91 - 92 db. All parts from Seas 3wc II.
