Hi paulspencer - I have used both outboard gear and software EQ (the software is impressive - hardware has to be really expensive to be flexible enough to do much) to EQ the room. The results have all been poor. Getting the speakers right and treating the room has been much more effective since I listen in the near field at low levels which renders room modes less of an issue. I use software EQ when mixing all the time, and an astounding variety of effects are possible including impulse response reverbs and the like. I love the sound of the system without the room intruding. Imaging, sound stage, frequency response all clean and uncluttered. It really shows up the weaknesses or strengths of comercial recordings, not to mention my own.
I don't spend much time ripping CDS since the super drive I have plays them straight just fine. I rip to full res .wavs for editing. MP3s - yes, sadly, the 128kb/sec MP3 has become the coin of the realm in production music, both for demos and sometimes, believe it or not, as finished product. They have a certain sound to them that people accept readily now because they are heard so commonly - dynamic compression of often already hyper-compressed signals. For certain music they sound ok, I guess. Of course, you can take a 24 bit 48k or higher resolution master and make a large mp3 that exceeds the CD standard 16 bit 44k resolution, but you get no size benefit. The algorythm, though "lossy", is not so much the problem as the meg/minute size requirements/resolution coming from the download mentality. Not much hi-fi there...
Cheers, NNK
Cheers, NNK
Personally I think the MP3 format sucks...distorted sounds, too much compression, poor resolution and the file size isn't that idea anyway.
Ogg Vorbis all the way. Rip at 400kbps+ and you'll have a hard time telling the difference from .WAV files.
I'm even hear a big difference between several models of hi-end CD players, not to mention compressed sound. Sony - is the best of I know.
Here's mine:
Technics SU8080 Amp, from the late 70s, I love this thing😉 Details here
Sony CD-PXE300 CD player, What HiFi golden award winner but not that I can tell😛
Technics SL1600 MKII wheel of steel
DIY 2 way speakers, I made them, Details here
Yury said:looks nice. do you have sub woofer?
Me? Not yet but its coming..... Damn this DIY audio bug, too many ideas not enough time
🙂 you're made nice work, let's finish it.
without sub your small loudspeakers hardly satisfy your requirement.
imagine! suddenly, deeper bass will burst into your sweet home..........
you have to do a little already 🙂
Yury said:🙂 you're made nice work, let's finish it.
Yes I know Yury
One of my favourite types of music is Drum and BASS so I am well aware of the lacking in low end here
I have been relying on the 15 inches of woofer in my car to satisfy lately😀
maxw said:
Yes I know Yury![]()
try to play http://www.artmaydan.org.ua/plan/insensible_ph.mp3
you'll be satisfied
Yury said:try to play http://www.artmaydan.org.ua/plan/insensible_ph.mp3
you'll be satisfied
I TRIED to play it and my poor open baffle computer speakers buzzed like a loud annoying blowfly! ... turned it down and the bass was delcious! ... who is the artist and what is the album?
pity to know it...🙁
I think you just have not codec mp3 like mine....
it's mp3pro version.
ok. Portishead-group. Pearl-album. insensible - song.
Yury said:Portishead-group. Pearl-album. insensible - song.
I can't seem to find this album 😕
I like Portishead alot, a bit depressing though.
I dont know what album this is eiher.
They have a track called "pearl" and a tracked called "Insensible" on their self titled album, maybe Yuri means that one?
This is a good place to search for albums and titles, eg:
http://www.freedb.org/freedb_search...ields=title&allcats=YES&grouping=none&x=0&y=0
Anyway back on topic...
yes, I mean http://www.freedb.org/freedb_search_fmt.php?cat=newage&id=930bb60b
1. 4:46 Insensible this song.
sorry for offtopic. let's talk in the music diyaudio forum about it.
but anyway, music for test our masterpieces - is very important
My new speakers.
Drivers:
Tweeter: Scan Speak D2905/9700
Midrange: Scan Speak 18W8545
Woofers: Ino Audio W85 (19 mm peak to peak)
Each woofer has a 40 litre box, tuned to 23 Hz. The 3" ports are located on the back panel. Midrange has a closed 10 litre box.
Drivers:
Yo Morello! I still want to listen to those! 😀
Here´s some more Ino for you, namely the bass modules with Ino W104, and the active filter cr8 (the small box with the glass apple on top. 😉 ):
my actual kit
-CLASSÉ Cap-101 integrated amp
-ROTEL RCD-1070
-Custom made Speakers using RF-7 10's and MB quart Tweeter in sealed enclosures with 12db/octave Solen x-over
-Custom made subwoofer using Audiobahn Alum15q (yes i know: car sub's...That perfom damned good !) in ported enclosures 9cu.ft.
- RBH-200 subwoofer amplifier (hidden below the red chair)
Next upgrade: ?? (maybe the new amazing Classé amp)
-ROTEL RCD-1070
- System Pictures & Description
