System Pictures & Description
Bassment prototype area.
2.5 way neo8 dipole crossed 800hz lr2 via behringer dcx2496 to 115l TL. TL hold dual RS225s.
from a single piece of birch. It's not the cheapest way but it's incredibly stiff. The top and bottom are 3/4" and the sides are 1 1/4" thick. All the pieces were CNC'ed.
Well, you're certainly right about stiffness😀
Did you use any bracing inside the cabinet? Given the wall thicknesses, it would probably be overkill, but still.........
Best Regards,
TerryO
Thanks Guys... No robotic lobsters for me though 😱)
I'm using Mach 5 MLI-65 Midbass drivers / HiVi DMA-A Dome Midrange / Vifa MG27SG2904 Tweeters
I had Solen design and build the x-over's for the mids/tweets since I didn't have the experience to do it myself... I'm using a DCX-2496 to crossover the mid-domes/bass... I'm Messing around with some T-Amps right now so I may actually go completely active soon.
I have some more pix taken during the process on another computer. I'll upload them later. Here's what I have on my notebook right now
The blocks of wood that you see inside I threw in as an after thought after realizing that I'd messed up the volume... The bottom compartment is now loaded with sand
Darp
