Here's the striplam section's for a 4 way I'm putting together .
Cheers
Darn clever. I look forward to seeing the end result.
Darn clever. I look forward to seeing the end result.![]()
Cheers mate
Reev Designs Awaaz
All:
Here are some photos of my system.
2-way bass reflex enclosure.
Vifa PL series 7" woofer
Peerless HDS Tweeter
External crossovers 24db/oct centered at 2.2 khz.
Subwoofer - 12" Peerless Woofer on 360 watt BASH amplifier.
All:
All:
Sweet!
Here's a mock up of the striplam ply & alloy baffle
Cheers
Mother of God! That's going to be breath-taking!
All:
How did you make the curve on the front baffle?
Cheers
This is looking fantastic!
Juggy, great looking system too
All:
They look better than bought one's
Cheers
The curve was made by first making a 10 degree cut using a table saw on either side of the front baffle lengthwise. This took care of most of the material that had to be removided, then i used a belt sander to curve the front baffle and ensured consistency using a template cut at a 36" radius.
Thank you for the compliments.
WOW!
And How long did it take for each baffle?
And how thick is the box?
WOW!
It took me about 4-6 hrs a baffle (pefecting), i went from the belt sander, to a palm sander, to hand sanding. Because the speakers were going to be clear coated, any variation in angle was going to be quite visible.
The box is 1.5" on all sides, with internal bracing and damping.
Cheers
Cheers
Details. What drivers are you using?
The wood work is fantastic. High gloss polish is so reveling of any errors yet you dared to use it. Fantastic work.
Hi navin
The drivers
Raven R1
PHL1120 6.5" mid
PHL3020 10" lower mid/upper bass
PHL5021 15" bass driver
It will be an active ystem driven by SET amps I'm building .
Cheers
- System Pictures & Description
