System Pictures & Description / Subwoofer Gallery
Sony woofer
Sony :wave2s:Xplod:wave2s: XH H99 8 Inch :violin:Woofer :car:
BP1Fanatic just saw your post. It sounded great while it was in the car. Went to a competition earlier this spring and it did 145.9 dbSPL at 42 Hz on 14.5 volts fused at 60 amps. It's in my living room now though as I gave that car to my brother but it sounds every bit as good there as it did in the car. It doesn't get low enough for true home theater use but for music it is amazing. I have a 15" Dayton classic in a 12 cubic foot enclosure port tuned to 17Hz for movie time though...
SuB WooFers
New SUB Box Design
:smash: J Audio 450W Dual voice coil sub speaker
:smash: X plod 200w Sub speaker
The Safewoofer
Been a while since I've posted here, but I've got another one for you all...
Dayton 12" Reference HF driver + a repurposed mini-safe. I got the safe for free and discovered it was the perfect internal volume for my driver (which I also got at a reduced price). Ripped the door off with some elbow grease and a crowbar. The Dremel tool attempt turned out to be futile. It sounds really great! The enclosure is totally dead due to the ~2" thick walls. Has anyone else seen a subwoofer made out of a safe? I searched but came up empty.
More deets here: http://rayban.vision/#!/projects/safe-sub
Here is 12" Velodyne subwoofer,closed cabinet,1200W plate amp with auto room correction, DSP,auto EQ,LPF,HPF,phase control,IOS application and a lot of other "things"...
Seems like a great build. What amp and auto room correction is it? How many measurement points you use? Does it take into account main speaker bass output when calibrating?
