Symmetrical amp clipping behavior - help needed
Problem with Tian probe is the transfer equation that you added, How do you know if this equation is correct?
Most people as LKA, use simpler way explained here, LTspice Stability of Op Amp Circuits - YouTube which unlike Tian can be used on Tina. Another method described by Bob Cordell can be used if the impedance of the feedback network is much higher than the output impedance, which is not precise for CFA.
A pole and zero are representing points on Nyquist polar graph for low pass and high pass cut frequencies. Your dominant pole for example is about 20hz.
I don't know, but I can see that Damir and Russell are using it (with great success), and they say it's good. Who am I to doubt it ? Have to trust someone...
It's a pity it's not Tina compatible, I forgot you are using Tina only...
Will check out the other methods - hopefully plots generated will be, as you say, simpler and more obvious.
Minek, you can use this simpler less accurate method, but be sure to remove AC1 from V4.
Kenneth Kundert walked me through the Tian method in a day-long presentation of the stability analysis tools available in Spectre (A SPICE tool for analyzing integrated circuits). He wrote the Tian analysis routine in Spectre. It is similar to the Middlebrook method, but more accurate with respect to feedforward loading. I am satisfied that it is accurate, as are the people who design every integrated circuit that includes an amplifier.
If you are doing a CFA, I think the Tian method is the only way.
The Tian method is actually included in the example circuits provided by LTspice with the download.
For those interested in some background on the Tian method:
https://kenkundert.com/docs/cd2001-01.pdf
Not sure if this plot makes sense.
GM seems to be minimal, while PM huge..
Different than Damir's last plot.
Judging from Damir's plot from post #43 (with C10=7pF) PM already improved to 18 degrees.
The latest sim (post #40) has C10=3pF and C8/C9 also lower, so I would expect further improvement..
Still experimenting..
OK, this is the latest plot, that at least looks like Damir's plots,
so I guess it's more or less OK.
PM: 26 degrees, GM: 13dB
Far from OK, but better than yesterday...
The thing is I'm getting different plots from Tian method, and from simplified method.
This one here is from simplified method. Plot from post #48 is from Tian.
Update: attaching Tian plot here (2nd atachement).
They look different, and of course produce different PM and GM.
What are the acceptable values for GM and PM, for an amp to be considered stable and build-able?
Looks like PM in perfect world should be > 45 degrees, right?
For full transistor implementations, PM has to be > 60 degrees. Loads and speakers can be weird and amp testers like to hook up dangerous loads, so I shoot for > 65 deg.
GM, I normally shoot for > 10 dB. My lastest design shows 8 dB GM, and I reckon I'm happy with it.
I'm not sure I am on the right track here. Using dadod's Tian model from post 22 I am getting a phase margin of around 60 degrees - the same number you have for gain margin. I have this around 17dB.
In addition to the first mentioned change with 100pF across R6 at 1k Ohm, I omitted the 10pF across U1 and made C10=39pF with 1k8 Ohm in series to form a step network.
This 1k load on op-amp, while making amp more stable, increases Thd and makes FFT not-that-flat-anymore, and instead of staying below 150dB, now it's spiking to 120dB.
That makes the double cascode most likely unnecessary, as Russell predicted.
Will keep simulating this, to see if there is some kind of acceptable compromise...
I've seen many amps driven like this with lower load, perhaps not as extreme as 10 Ohm, but maybe 33 or 47 will do..
