SX-Amp and NX-Amp
Hi Andrew,
It is 555ohms. I will try to sit down today and create a couple schematics. One with VBE for each transistor and voltage drops on resistors and another with voltage to ground. Somehow I have to get to the bottom of this. Obviously, these boards can produce a working amp so I must have a bad or wrong part somewhere. I need to find it before I blow up any more parts.
Blessings, Terry
OK, I sat down and measured everything. I marked up two schematics. One with VBE and resistor drops. The other has voltages compared to ground. I can see that the voltage at the base of the NPN outputs is low so I replaced Q12 again with no change. Hopefully one of these two schematics will help.
Thanks, Terry
Hi Andrew,
There was one thing that I noticed and forgot to note on the schematic is that the voltage at the junction of R1 and R3 is -10.32V. If I adjust R3, the voltage will move toward zero but the offset becomes more negative. I'm not sure if that matters but it is something that didn't seem right to me.
Thanks, Terry
This does not seem right. If you measure at the junction of R3 and R1 you should get smooth adjustment from -10 V all the way to + 10 V. The amplifier output offset adjustment range should be about +-0.5 V IIRC. Can you recheck the voltage at the junction of R1and R3 and that you get the full -10 to +10 adjustment range?
It looks to me like there is a problem in the front end that's causing an offset. If I look at all the other voltages, they seem to be in the correct ballpark.
It could either be a wrong value (check all the 15 Ohm resistors and locations) or a solder flash (i.e. bridge or short) somewhere. The symptoms you are seeing could also be because of very high gain - eg if R11 was shorted or very low value. One thing you could do is inject an input signal and check that the gain is about 37x and not much higher (remember to keep J2 shorted otherwise your gain will be 19).
I have to start work now, but will check back in a few hours again. Hopefully we can make some progress.
