Super Regulator
Thanks Rick. I found that out the hard way, but impatience got the better of me this time and I had to make a start, although some resistors hadn't arrived yet.
I purposely left the smd opamp for later as someone mentioned testing voltages before installing the opamp. It looks like that might have been a reference to socketed opamps.
Yes, leave the opamp socket empty until some testing is completed successfully.
A soic leaves you no choice but to risk power on with the expensive opamp already in place.
Thanks Andrew.
I logged onto my computer for the regulator stuffing guide to confirm smd orientation, and found your message waiting for me! Your timing was great!
Are you able to point me in the right direction for testing?
I have a relatively good dvm, as well as oscilloscopes 20mhz and 50mhz.
Testing my super regulator
Pics of the positive regulator minus the opamp.
Without the opamp loaded, pin 3 of the opamp should measure about 6.9volts assuming:
- you have used the LM329 reference
- you have shorted the +ve output to the +ve sense input on J2
- the +ve return is shorted to the +ve return sense on J2
J2 has 4 connections, pin 1 at one end, pin 4 at the other. Short pins 1 and 2. Short pins 3 and 4. ie in this instance it does not matter which end you call pin 1
Also check the output voltage.
Because the opamp is not loaded the output is unregulated and will be higher than the regulated voltage.
Rick
:cheers::cheers:
Rick
I plan to instal the regs in a marantz cd63 or cd67.
Would an 18v 'wallwart' power supply be suitable option for testing?
I also have a 0.75va 2x15v encapsulated transformer that I could use to build a quick and simple power supply for this purpose.
An 18V wallwart (assuming it is DC) is fine for testing. Since it is only one polarity (I guess) you need to test the pos and neg reg one at the time, but that's OK. This is like a go/no-go test.
For testing the neg reg, put the pos output of the wallwart to gnd, and the neg output of the wallwart to the neg reg input.
Jan
"a simple power supply for the super regs" sounds like you mean rectifiers, filter capacitors, and possibly other components, that produce filtered, but not regulated, "raw DC" as input to the super regulators.
A fairly standard design, with typical components and typical circuit topology, is attached. "S1Dot" is the phase-dot end of secondary#1 , while "S1_ND" is the no-phase-dot end of secondary#1. Secondary#2 wires are named "S2Dot" and "S2_ND". "Shield" is the transformer's electrostatic shield (purple wire on an Antek AS toroid), if present. "To_Star" is the star ground. As shown, the supply produces +28V @ 4 amps and -28V @ 4 amps. With a 500mA Jung/Didden super reg, you would draw less than 4 amps, so maybe you might modify the circuit to use smaller capacitors and scrawnier diodes.
If you decide to keep the transformer snubbers (C1, C2, R2, etc) you will need to tune them for the particular transformer you are using. Search the forum for "snubber" and/or "Quasimodo" to learn more.
