STAR Pure DSD DAC-Signalyst New
now follow me setup:
1- The gain setup +6dB DSD all or 0dB.
2- Volume : 0dB, if you use Pream
3- Output: DSD x8
Note: in the Oput DSD x1 , 2, 4,8, you can setup for test with you like
***The sound will change with the choice of DSD x1-DSDx8,
High resolution audio will be less than at DSD x1, and warm and natural sound will be better at DSDx8.
Try it and let me know the result. thank you!***
thank your advice!
quanghao
My STAR DAC does not allow to change output DSD rate. Display shows DSDx8 and I cannot setup other DSD output rate with CH+/- buttons of remote control in setting mode. In non setting mode the CH+/- buttons are working and switch input. Please advise.
BR,
1543
May I ask if you use an output transformer or if you connect directly?
I did some experiments with my own Soekris dam1941 with output transformers.... Lunfahl, amorphous cores from smallish ll1674 over 7903 to ll1692AM... not matter what, they add a metallic, technical sound. The direct connection to the grids of my tube stage wins anytime. Nit sure if we have no choice as ti use output transformers, but i doubt that those chinese 40$ a pair guys are better than the 500$ LL1692am which is best of the Lundahls i had on hand.... but no tramsformer in the aignal path is best.
I did try chinese, Ludhal, teramoto and bisesik transfomers from this thread:
Output transformers for DACs.
I did not tried it with Soekris (I used it the way you describe: no transfomers), but used them in another applications (AKMs,ESS,AD DACs). Bisesiks ones was the best!!! So if I ever had to use transformers I would definatelly ask bsiesk to make me one.
The DAC uses transformers, do not know which type as the transformers are not visible due to shield can.
I have read somewhere in a forum that first Signalyst DSC1 included a transistor I/V output but the transformer output should sound better. A transformer is soundwise never 100 % transparent as you could also confirm by your experience. Would like to try transformer less version of the DAC. Anyone has a Signalyst DSD w/o transformer output and can share details?
Hmmm... the Soekris is a R2R Dac as well... and oitputs 1.3Vrms I believe with 600 ohm, so i/vconversiin is already done.
I assumed that the stardac has a similar spec? What is it output specs actually?
There is no I/V stage on Soekris nor in Stardac, because those are voltage out dacs. Transfomer are used to galvanically isolate those dacs from preamp or amp and maybe as LPF.
BR,
1543
Yes, the last firmware is lock to DSD 8x because there is no reason to set lower DSD mode
It is not possible use the Star DAC without the output transfomers because it have a differential output stage and it is necessary an I/V like show in the DSC1 schematic.
I think is better a good output transformers than an opamp but thi si my opinion.
In the case of Soekris probably is better use no transformers on output but this is an R2R DAC very different from DSC DAC.
We have selected these output transformers after many test also comparing them with high cost transformers such as those mentioned by you.
I have a DSC2, using Pavel's V2.5.2 boards, with Lundahl LL1684 transformers and it sounds amazingly good; very organic, natural sound with no sense of a "...metallic, technical sound'. Of course, YMMV.
