That's a very good price.😱
I find the CP-2500 pots that slawney posted above outrageously expensive.
With that kind of money I would buy the Dact.
So, the "super-conductive plastic poti" from Germany mystery is solved.
PD: "It looks like TKD pot that someone was selling on a forum, and also available from percyaudio.com"
If not the same TKD as at Percy, then one very similar. Percy Model # CP2511. Thel Model # CP2500.
Carlos: "outrageously expensive"
Percy: Thel:
$62.50 stereo Eu85.00 (approx $102)
$42.50 Mono
$73.00 balance
The reasons Thel gives for superiority of TKD (fewer solder points, and fewer material transitions) are interesting, but also apply to PEC. To think that for years he has been bandying the superiority of ELNA selector switches outfitted with Welwyn resistors ... and selling both to a good profit! 🙄
Has anyone compared TKD and PEC? I always wanted to try that TKD from Percy... 😀
Best regards,
James
Percy: Thel:
$42.50 Mono
$73.00 balance
Best regards,
James
Konnichiwa,
Well, this is a general thing I have observed on Pots, be they Carbon, Cermet or Plastic. I always find that the linear version sounds MUCH BETTER than the "audio taper" one. I have no explanation for this, except perhaps that the different track sections have different resistances per degree rotation which suggests different material combinations which are most likely applied in a manner that causes distinct "breaks" in the structure of the track. With some pot's it is very easy to see these sections.
My recommendation is that if a TVC is not affordable to use a lawfaked linear carbon and/or cermet pot or indeed the 10-Turn Wirewound pot's previously discussed. You can easily "gang" up the 10-Turn dual mono pot by using a string or rubber belt and pulley system with shaft extensions to the front.
For lawfaking linear Pots consider a 20:1 ratio between lawfaking resistor and Pot and consider the Lawfaking resistors value the nominal resistance (load on source) and output impedance. The lawfaking resistor will have a fairly large impact on the sound of the lawfaked pot, even cheap large diameter conventional carbon pots sound surprisingly good that way using the right lawfake resistor.
Sayonara
KT said:Brian or Peter, do you know if the log version sounds the same as the linear version?
Sayonara
Kuei Yang Wang said:.....For lawfaking linear Pots consider a 20:1 ratio between lawfaking resistor and Pot....
20:1 ratio is to high.
Ratio 8 to 12:1 gives better resaults, IMO.
Milan
That is what I heard from other sources as well! As such I have just included the advice to use a Law-faked pot on my pre amp page at Decibel Dungeon.
(Yes Jan D has pointed out the error with the pot picture and I am correcting it)
I have recommended a resistor about one/sixth the value of the pot, not 1/20th.
I hadn't realised that T. If that is the case, it doesn't make much sense to Law-fake a 10K pot with a 1K5 as that would be a ridiculously low impedance to work into! Is that correct as I would like to ammend the pre amp page as it is aimed at beginners?
Konnichiwa,
I find that 1/6th does not give not the required function. I know who insists that 1/6 is the right value for faking audio taper and as usually that person is dead wrong.
Common "Log Law" Pots have an attenuation of around 20db at "12 O'Clock". For that to be present in a lawfaked linear pot you need with the pot set at 1/2 rotation 20db or more attenuation. That suggests a value for the resistor of around 1/10th of Rp/2 or 1/20 of the resistance of the Pot. I recommend a 10K/250K combo as minimum for audio.
It is correct insofar that when you have the volume control fully up the input impedance of the Pot/Resistor combo is Rp//Rlf so it is 1K5//10k or around 1k3. Once you attenuate the input imedance goes up quickly. At 6db attenuation it is around 2K7 and at 20db attenuation around 9K....
Sayonara
Nuuk said:I have recommended a resistor about one/sixth the value of the pot, not 1/20th.
Nuuk said:I hadn't realised that T. If that is the case, it doesn't make much sense to Law-fake a 10K pot with a 1K5 as that would be a ridiculously low impedance to work into! Is that correct as I would like to ammend the pre amp page as it is aimed at beginners?![]()
Sayonara
I once tested a 100k linear pot before an (unbuffered) NI GC, that had 22k from NI to ground.
Didn't like the result at all.
I ended up removing the 22k resistor and using a 25k log pot.
I think that the values recommended by Kuei are more like a real log pot.
Peter,
I'm trying to decide,which pot to buy for my GC.
At the moment I have some plastic cheap Piher
pot at the input.
All I could find here where I live are Blue Alps
and Alpha pots.
Blue Alps are much more expensive.
Do you have any experiences with Blue Alps;
are they good for the price or should I go for Alpha?
Regards;
Matjaz
pot at the input.
and Alpha pots.
Regards;
Matjaz
Kuei:
"My recommendation is that if a TVC is not affordable to use a lawfaked linear carbon and/or cermet pot or indeed the 10-Turn Wirewound pot's previously discussed. You can easily "gang" up the 10-Turn dual mono pot by using a string or rubber belt and pulley system with shaft extensions to the front."
Would you recommend a PC-mount bulk metal foil trimming potentiomenter like the Vishay 1280G as well?
In terms of ganging it up, I would try to use gears entirely. Because the trimmer would be mounted close to the power op amp, a rubber belt would probably stretch and dry out due to the heat.
Wirewound pot are designed mainly for DC applications and have big inductance, which make error on high frequency.
Konnichiwa,
Probably not. Pot's are intended for very regular change of value, trimmers are intended to be "set once and leave. They won't like Volume control service one little bit, in the long run.
Sayonara
slawney said:Would you recommend a PC-mount bulk metal foil trimming potentiomenter like the Vishay 1280G as well?
Sayonara
Konnichiwa,
Are you quite certain? Have you actually MEASURED this?
Sayonara
Upupa Epops said:Wirewound pot are designed mainly for DC applications and have big inductance, which make error on high frequency.
Sayonara
Igla said:Peter,
pot at the input.
and Alpha pots.
Regards;
Matjaz
Although I was using blue Alps in a past, I never really compared them. But since Alpha is available for you, and for the price you can't go wrong with them, I would suggest to try those.
You can always upgrade later.
To Konnichiva : 600 Ohm - ( measured by my friend ) at 100 kHz drop is 1 dB. 10kOhm at 100 kHz drop is more than 3 dB ( depend on type ). It is not much, but exist it and by higher values it will be great. By the way, how you can make with this pot log. curve ? With linear curve we are back in early biggining of electronic 😉 .
Upupa Epops said:To Konnichiva : 600 Ohm - ( measured by my friend ) at 100 kHz drop is 1 dB. 10kOhm at 100 kHz drop is more than 3 dB ( depend on type ). It is not much, but exist it and by higher values it will be great. By the way, how you can make with this pot log. curve ? With linear curve we are back in early biggining of electronic 😉 .
I think it was quite explicitly explained that they should be law-faked by means of a law-faking resistor?
Konnichiwa,
The -3db seems a bit low on that, based on my experience.
There are any number of ways of doing this, however with a 10-turn Pot I did not find the linear law a problem when I used 10-turn pots for Volume control.
This is not to say that it is the ultimate solution though. I prefer BTW wirewound attenuators with a VERY HIGH inductance.... ;-)
Sayonara
Upupa Epops said:10kOhm at 100 kHz drop is more than 3 dB ( depend on type ). It is not much, but exist it and by higher values it will be great.
Upupa Epops said:By the way, how you can make with this pot log. curve ? With linear curve we are back in early biggining of electronic 😉 .
Sayonara
There dosn't seem to be alot if difference (see pic below)
They are also available at: THLaudio
James
slawney said:I always wanted to try that TKD from Percy... 😀
I believe Percy offers money back guarantee. If you don't solder the components, but use for instance aligator clips or sockets, you might test the TKD pot and in case you don't like it, still be able to return it.
Peter Daniel;
the stepped attenuator in the shunt position, is it constructed by a long serie of resistors or do you use only one resistor at the time to GND?
Also it would be interesting if you could try a simple metalfilm (vishay) voltage divider, using low value like 1k for the series element, and run it against your TVC.
High values and series attenuator like DACT is a no no IMO. If a stepped attenuator is to be used, it should be a two element shunt solution with lowest possible value for the given circuit.
You mentioned something about one/some of your volume devices "almost as transparent as a piece of wire" how did you come to that conclusion?
/Peter
/Peter
- Chip Amps
- So I did try all those different potentiometers
