SMPS powered small cl. A amp
No, but when I tested laptop SMPS bricks I saw that some of them have minus output node connected to safety earth so connecting two such PSUs in series would short-circuit one of them.
Disconnecting the minus node from safety earth is mandatory in that case.
Thank you for bringing up this topic. I am also very interested in SMPS for power amps.
I made a first try with SMPS on my Pass XO24-6 but I am not fully convinced.
I had quite a bit of residual 50Hz hum and its harmonics. This was audible when close to the speaker.
The linear PSU which I put together from simple LM317 based regulator was much better. Interestingly for me: The lin PSU benefitted a lot from connecting the transformer shield winding to saftey ground.
Attached is a sound card measurement (on the XO-24-6 low pass output) which shows the LM317 supply compared to a Meanwell APV-18. Also tried Meanwell IRM-60 which was slightly better but still much worse than the lin PSU. Adding additional RC elements to the SMPS output were only slightly better.
This is my 2nd ClassA amp powered by SMPS.
My M2x picks up hums easily from a nearby trafo previously, and there are many ways to reduce the effect by using Mumetal shielding. The other problem is the ground looping noise that I struggled with this amp.
After swapping to SMPS, all the above issues are gone for good, now it super quiet, no hums, no hisses. Time to enjoy this amp after a long tinkering effort! Now no longer need any MuMetal shield.
This smps powered up a total of 264mF of capacitor bank every time without a sweat!
I have never been happier with this PS setup.
I got mine from Micro-Audio. Great support he provides.
I did power up the ClassA amps without cap bank at first, they were totally quiet already!
Then i put in 60,000uF for my F6, and i love it.
This M2X got 264,000uF, not a must, but since i got the Universal PS board hanging around, so i used it.
You may run it thru using some smps filter circuit if that makes you feel better, but i won't do it till I see bad critters in my supply rails when i got the time to check. I ran out of capacitors trying to trip this SMPS to go into failsafe mode, it just powers up smoothly without any hiccups.
The ripple and other noises vary among the products out there.
Of the ones I've tried so far the best luck has been with Meanwell and Triad.
If the supply rejection of the circuit is good, you can often get away with just
a simple cap to ground on the rail, but if the noise is higher and/or the psrr is
not good, then a filter is necessary.
This is fine, but there are usually limits to what a switcher will start up into.
If the circuit draw is initially high as with a big bank of caps, many switchers
will go into protect mode.
With the P ch version of the DIY VFET, we did well with a Meanwell 36 volt
switcher and a simple L/C input filter. The N channel version has a lower psrr
and needed more filtering, ending up with a relatively large R/C network for
each channel. It loses a little supply voltage, but the circuit worked as well
as the L/C and filtered down to below 120 Hz.
I've been experimenting with the idea of inserting a specially optimized Darlington capacitance multiplier, between the SMPS and an enormously large bank of electrolytic capacitors.
The voltage waveform at the input of the Darlington is filtered by a simple RC lowpass, so it's a rising exponential
  • Vbase = Vsmps * {1 - exp[-t / (Rbase*Cbase) ] }
We want to make sure that the total charging current is less than the SMPS max output current.
  • Icharge_caps = Cenormous * dV/dt . . . . and must be <= Imax_smps
dV/dt at the emitter is the same as dV/dt at the base, because it's just a Darlingtom emitter follower. dV/dt at both the emitter and at the base, is just the derivative of the expression above
  • dV/dt = dVbase/dt = Vsmps / (Rbase*Cbase)
Inserting this into the max current inequality,
  • Imax_smps >= Cenormous * Vsmps / (Rbase*Cbase)
Eureka! We can install ANY amount of filtering capacitor we like, simply by choosing a suitable (Rbase*Cbase) timeconstant. Here are a few examples:
Code:
Vsmps    Imax_smps    Cenormous   (Rbase * Cbase)
 36 V       4.2 A       3300 uF      0.03 sec
 36 V       4.2 A      22000 uF      0.20 sec
 36 V       4.2 A     115000 uF      1.0  sec
 38 V       3.9 A      20000 uF      0.195 sec
The fourth row attempts to carve out a bit of safety margin, by assuming a higher than normal SMPS output voltage and a lower than normal SMPS "hiccup mode" threshold. The math says 0.2 sec, so be conservative and choose an R*C timeconstant significantly longer, such as 0.5 sec or even more.
Clearly for such large timeconstants we'll need large values of Rbase . . . and that's why I'v chosen a Darlington arrangement -- Darlingtons need very little base current so they can operate with very large base resistors. Yes you lose two diode drops going thru a Darlington. And that's in the best case scenario, where the input transistor operates at a VCE of only 0.6V, while the output transistor operates at a VCE of only 1.2V. Plenty of transistors defecate the bedsheets at these low values of VCE, so measure them beforehand and choose wisely.
Here's what a good candidate looks like. VCE on the horizontal axis, ICE in milliamps on the vertical axis. Notice that it behaves nicely even below VCE=0.6 volts.
Finally, remember that at the instant of switch-on, the Darlington will have 36V across it while it conducts 4.2 amperes. That's an instantaneous power dissipation of 151 watts. It will be very important to study the SOA curves, and also to select a suitable heatsink!
_
