SMPS powered small cl. A amp
A friend of mine had put to my attention this project a while ago. I had read the thread and found that it was an interesting design. So, time had come to give it a try.
To make things easier, and since this is a quite simple circuit, I decided to build it on a breadboard, for the sake of simplicity. In just less than an hour, I had built one channel and powered it from my lab regulated PS. The problem I encounter is that, whatever I tried, the P channel always draws 200 mA more current than the N channel. Increasing the current on the + side, increases accordingly the current on the - side and vice versa.
Checking the amp on the oscilloscope, I didn't notice any flaws: the signal is perfectly symmetrical all the way to clipping.
Any suggestions here?
Regards,
Evangelos
This might have to do with differences in FETs because they were not matched. Did you measure them or attempt to match them?
Try this method:
Even one of these $10 component testers is better than nothing:
As far as I know, never N and P channel MOSFETs cannot be matched. Usually, the P channel has a higher Vgs than the N channel.
And, yes, I have measured them. I have 4 pairs of Exicon lateral FETs. All N channel FETs have a Vgs of ca. 1.4 V, while P channel FETs have a Vgs of ca. 1.9 V.
Adding a source resistor to the P MOSFET would negate the square law transfer characteristic of the laterals.
juma states in his presentation in the first post of this thread:
"We use Laterals without source resistors so we can exploit their square law transfer characteristic and the exact bias current value is not that important but you can play with it."
I'm trying to interpret this sentence regarding the bias current value. Does he imply that a difference in bias current is acceptable?
